![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
The socket I got was 13mm from laser The JLR part from Duckworth that arrived the Wednesday before Easter is genuine and fitted the 13mm socket. a 14mm socket is not a usual size? |
Harry Hotspur Member Since: 14 May 2019 Location: Scotland Posts: 3 ![]() ![]() ![]() |
Thanks Tinman. I suspect that I have been given the wrong new part as although it looks right it is most definitely has a 14mm chrome retaining nut and the Laser tool is correct for removal at 13mm.
Hi Part LLRO 52169 price £100.73 The nut was black not silver? Tip when you start work place a cloth below where your working it's a good safety net.
All now resolved thank you Tinman - the parts lad was advised by his workshop of the wrong sensor (given the inlet manifold one) but had the part no. you gave me in stock too - same price. Cheers! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Guys, I’m in the middle of this job, but unlike most of the success stories above, my car with 200,000 miles decided it would put up a better fight, and the nut sheared off. Even lots of soakings, it wouldn’t move. So, with a prospect of getting a right angle drill in there, and trying to drill and tap out the old remains and screw in a new one, I decided to come indoors, and sulk a bit, and few cups of Yorkshire tea…but had a little Eureka moment.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Sorry to hear you’re having so much trouble.
just a little update. my car was stuck in red warning on the 'dpf full' alarm. I connected up the new sensor, and left it hanging, on the side of the engine. so not at any high exhaust temperature... and set my IID tool to 'engine' service test mode, and saw the 'forced regent' mode. car was warm, and I took the test, on a motorway. soot level was 31.5g. after around 5-10 mins cruising, it started to fall, very slowly. and about 20 mins later, it went to about 4g. I pulled off, and coasted to a stop, and by the time I parked. (went below the 25mph (green) speed, it was down to 0.3g. so a successful regeneration.. I haven't looked at the total number of successful regenerations, as I made a note of some numbers just before. but it seems that the IID tool ,can perform a forced regeneration, when in red. you get a menu, with red values, like speed and engine temp, which when green, starts the regen, and after about 10 mins, it starts to fall, and goes green at about 23grams, and continues to fall. I was very pleased, and although the red alarm triangle remained, until I switched off, it seems to have done the trick. on restart, all alams were gone, and the car was back to normal.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Buy a short extension OBD cable with a 90 angle connector on one end. That will hold the flap and the iid will be well out of the way |
Glad to hear it worked Cheers, Greg
It sounds like Pat has put the Forced Regen facility on general release now if you say software Version 3.
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
How will that hold the flap? |
The cable can be attached by using a sticky backed cable clip. Mike G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Hi guys.
