Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement
Page 5 of 10 <12345678910>
MTG2020
Yes. It was in RP before the yellow DPF warnings.
Post #599474 3rd Jul 2021 7:48am
GGDR
Ah I see.
Ok battery reset might be worth a try too.
Have you got the EML symbol on too ?
. Cheers, Greg
Post #599482 3rd Jul 2021 8:31am
MTG2020
No EML.
I did a full reset using the IID tool. Isn't that the same thing?
Post #599498 3rd Jul 2021 10:10am
MTG2020
No have the EML light, haven't read it yet, but assume it will relate to the red DPF warning.
This is ity first car with a DPF, so didn't really understand the problems it causes, with short journeys. Although I've been carrying out the dynamic regenerations when the Amber warning appears, I don't think it was enough and it is now full or blocked, hence the red.
I have contacted Pat at GAP Diagnostics asking if I can perform a forced regen using the IID tool. You can by updating it to the beta firmware version 2765.
I will do this once I have finally go that sensor replaced.
I think I may have wasted a ton of cash on parts I didn't need. Hey, ho.
If I could legally delete the EGR and DPF.
Post #600143 9th Jul 2021 11:00am
MTG2020
i most definitely would....
Post #600144 9th Jul 2021 11:01am
physio
United Kingdom 2011 Range Rover Vogue 4.4 V8 Barolo Black
Hi Great detail. Do you think a sooted up, choked EGR valve would give the same error code.
Post #615482 9th Dec 2021 12:22pm
physio
Hi
I have Exhaust gas recirculation Temp sensor A -Circuit high (P040D) and also EGR Sensor B Circuit (P0486)
My question is do they both need changing or can the sensor affect / cause the P0486 to flag up or vise versa? Help please
Post #624978 28th Feb 2022 11:35am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Me too, only an occasional fault though!
Post #624996 28th Feb 2022 3:04pm
Baltic Blue
I have had the PO 40D fault permanently for at least 5 years, but I have never seen PO486 ?
Post #624997 28th Feb 2022 3:13pm
JoolsB
Now it’s getting a bit more regular. The fault is always there but sometimes it goes into RP, no other fault codes come up and it does eventually clear, either on thE IID or just by leaving it for a while..
I’m thinking that I’ll limp on for a few weeks and when it gets warmer, tackle this, the donut hoses and oil cooler seals all in one go.
Post #627566 1st Apr 2022 8:18pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Well, so far I`m stripped down and have cut the sensor with a hack saw blade? moved the heat shield out of the way and got the socket on.
I did soak the manifold over 3-4 days with CRC but it is a right Censored to move at the moment? just worried about shearing the Censored off? Big Cry
Post #628568 13th Apr 2022 11:29am
GGDR
Mine was tight but with a 'crack' it moved
As long as you are confident the CRC went directly on/down the sensor should be ok
. Cheers, Greg
Post #628571 13th Apr 2022 11:35am
Tinman
Yes, I'm sure it went on as I checked each time with the borescope nice to have the light on the end? Having a cup of tea now, waiting for some more CRC penetration? then have another go, not in any rush.
Post #628578 13th Apr 2022 11:54am
Tinman
Well got it done over 3 days? and plenty of cups of tea.
I would suggest getting the right angle to undo the thing, the method that is recommended should be followed to the letter?
Also, any other advice that has been suggested, Mine was tight so warmed the engine up after soaking again and it undid the Censored
It can be done and will save 2.5 hours of JLR cost plus parts.
Level of difficulty 11 out of 10? patience required more than you would think Big Cry Checked the IID for faults none found and no fuel smell from the exhaust?
Big thanks to GGDR for the wiki post. Thumbs Up Bow down
Post #628877 17th Apr 2022 12:12pm
GGDR
Well done Tinman, welcome to the P040D-00 club Shocked
T-shirt in the post. Razz Cheers, Greg
Post #629178 20th Apr 2022 5:31am
