![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Don’t worry about it....
RR_Overlander Member Since: 27 Aug 2020 Location: England Posts: 6 ![]() ![]() ![]() |
Hello All
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 56 ![]() ![]() ![]() |
Thanks GGDR for this outstanding write up, carried out this today went pretty well thanks to the heads up in particular, specific tools - the flex head ratchet a must.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Pleasure QT, glad it went well |
I had this on my 11.5my 322 and it caused massive over-fueling issues! Bought my 405 and guess what! Yep, same again and it stank like an old ice cream van! I think some maybe fail in an open circuit manor and some fail in a closed or short circuit manor? My failure on the 322 kept overfilling the DPF! Regen after regen until BONG! red light DPF FULL! Thats why I had it changed on the 405 instantly after finding the code! ![]() |
Tattiepicker Member Since: 01 Apr 2021 Location: Aberdeen Posts: 51 ![]() ![]() ![]() |
Homemade lubrication Lance, worked a treat.
Hope this clears the error code for me. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Craig - does the sensor sometimes fail (in one of your 2 options) but sometimes not show the code in your experience? I am still chasing an issue on a family friend's car. Documented here: https://www.fullfatrr.com/forum/topic54864-75.html It is clearly trying to regen (a lot!!!) but the temp doesn't go above 600, the oil in dilution is increasing too quickly and the soot keeps going up and doesn't do any active burns. It does do micro burns and brings it down about 1 g on a longish run. We had a force regen done (it took a while to get it initiated) but it's still doing the same i.e. demanded regens go up, oil diln goes up, soot goes up, bank 1 sensor 2 doesn't go above 600, coolant temp is normal around 94'C. Something is clearly not right and it's bloody annoying ![]() Thoughts? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- Last edited by DrRob on 4th Jun 2021 3:50pm. Edited 2 times in total |
Rob,
MTG2020 Member Since: 24 Feb 2020 Location: Caerphilly Posts: 35 ![]() ![]() ![]() |
Hi All. I am currently in the process of changing this sensor based on your excellent write up.
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
Bit confused about identifying which sensor is actually bad.
MTG2020 - not sure having this code will affect your RP. Some mechanics will insist there must be no error codes but I'm not so sure. What I suggest is you buy and plug in a new sensor (around £75) and then, without going to the trouble of doing the impossible job, you can try to clear codes and see if that removes your RP. Assume you have an IIDTool ?
Hi G. I have since replaced the throttle body and still have the RP issue. My last hope is the EGT, as I now have the added issue of not bring able to regenerate the DPF and have a intermittent red "go to dealer" warning. Deep joy....
