![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
j9ffy Member Since: 27 Mar 2018 Location: Indre Posts: 33 ![]() ![]() ![]() |
Six point version of the special tool arrived this afternoon (outstanding price/delivery speed to France etc from an online auctioneer in uk). Took five mins to bed-in the sensor ( I did this "just so" - really didn't want to over-tighten it). GGDR is spot-on about being careful not to cross-thread it, so I had spent a couple of hours yesterday getting the sensor carefully offered-in etc... I'd pay close attention to getting this right.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Really glad it worked out, well done!
Corsica Member Since: 03 Jan 2019 Location: Corse Posts: 50 ![]() ![]() ![]() |
Bonjour j9ffy
Evening all - just going back to Corsica's question a couple of posts ago... what would be the effect of cutting the sensor and then driving the vehicle with the sensor cable severed? My guess is that this is effectively just going open circuit so could be tested by simply disconnecting the sensor at the harness connection to see what the effect is (eg putting the vehicle into limp mode etc..). I'm afraid I didn't check this whilst doing my repair so don't know the answer for certain... does anyone happen to know?
Yes well you could just undo the connector for a test. It won't go into limp, it will be the same as a failed sensor and the error will continue to show. So not too much point.
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 27 ![]() ![]() ![]() |
Hi All
Nice work, and nice additional tips!
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
Any idea if having this fault code present would prevent a DPF regen? |
Not at all in my experience
Ok, that sounds good. Do have another question. In your other thread you mention this can be a cause of a full DPF?
That's why I changed the sensor - to find out if that was helping to fill my DPF.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Code has no impact. Lots of evidence of that from multiple folks |
Ok, all makes sense, thanks both. |
