![]() | Home > Technical (L405) > front knuckle cracking |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
From what Ive seen and understand from this thread, the crack occurs due to electrolytic/galvanic action between dissimilar metals causing corrosion which expands and then cracks the part. Would it not be a better solution to use the same metals? add grease to stop the corrosion? machine a spiral groove or similar to leave room for expansion?
James Brown RR Member Since: 26 Jul 2021 Location: Cheltenham Posts: 22 ![]() ![]() ![]() |
What is the VIN Range that have the problem? Not sure which Russian video you are referring to. SDV8 Vogue SE
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 131 ![]() ![]() ![]() |
HI number76
number76 Member Since: 30 Oct 2013 Location: UK Posts: 47 ![]() ![]() ![]() |
I don't think you will find that there is any difference in the Russian vid, as they would have just ordered the parts for that VIN number like most do, as probably just like the Red Lion did for yours. So they would be new units for that year.
Pictures of the top of new knuckle, one thing i did come across when looking at parts is you can get the top wishbone that has the balljoint on that goes into the top of the knuckle in +5mm and -5mm does anyone know the point of that if fitting to a standard L405 with all orininal factory parts on. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
The +5mm and -5mm versions are fitted for camber adjustment but IMO after-market camber adjusters would be a far better option. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Would a simple solution not be to split the joint at service time clean and refit? There is nothing that can't be fixed with a hammer😜😜
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
Good Morning ur20v
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
For reference, from the service manual, concerning replacement...
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
Suspension, brake and steering fixings are advised to be replaced on almost all models...
Thanks for the advise about the bolt, as the garage i used is Land Rover approved with a fully approved Land Rover technician i can only asume that the bolt was inspected and found to be safe for reuse. |
Often critical bolts are coated with sealant which are single use unless cleaned and sealant re-applied. Also some locking nuts destroy the thread of the bolt as they undo which then requires a new bolt and nut. |
They are nylock nuts so the bolt threads will not have been damaged and the nylock nuts must have been fine for them to be reused but to be honest the old nuts and bolts anoy me as you can see them under the wheel arches against the nice clean knuckles when at standard height so they will be changed to nice clean new once, the good thing now is everyone that reads this topic will now know that if they change the knuckle the top nut and bolt that joins the knuckle to the top arm is not recomended by land Rover to be reused .
