![]() | Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Found some time yesterday and had another go
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 199 ![]() ![]() ![]() |
Hi Range Rover L322
The Ali adapter head arrived today completel with split pin. Well machined item which fitted to the shaft with ease. Having aligned the holes from one end with drill bit or anything you have it’s ready for the split pin. I found it necessary to close the pin up enough to hammer it through but no problem if anyone wants to have a roadside Jack for the L322 !
Just come across this thread. Will make up some adapters this weekend for my pair of sprinter jacks. 2012 TDV8 Vogue (L322) |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 337 ![]() ![]() ![]() |
Does anyone know if anyone is still doing the adaptors? The eBay links upthread are all dead now. 2017 4.4 SDV8 Autobiography in black
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/125665105349?mk...edia=EMAIL G reg 2.5VM Vogue Portofino red 1991- 1999
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
. deleted by author 2012 L322 4.4 TDV8 AB low mileage - a peach
The link I added is NOT drilled, just the top ready for DIY drilling.
I was hoping for pre-drilled really.
Calisto22 Member Since: 07 Nov 2024 Location: Gloucestershire Posts: 3 ![]() ![]() |
I took the chance and went for one of these as seems good value. I know the lift height isn't as good as the Sprinter jacks but will see how I get on.
