Home > Maintenance & Mods (L322) > LR set to recall all 2011MY FFRR's for new AGM battery
Page 2 of 13 <123 ... 111213>
dan_uk_1984
jez000 wrote:
This is taken from a Wiki page on AGM batteries:
Advantages
All AGM batteries have enhancements over flooded lead acid batteries:
Purer lead in the plates, as each plate no longer needs to support its own weight, due to the sandwich construction with AGM matting. Traditional cells must support their own weight in the bath of acid.
Fluid retention - un-spillable
High specific power or power density, holding roughly 1.5x the AH capacity of flooded batteries due to purer lead[citation needed]
Low internal resistance allowing them to be charged and discharged quite rapidly
Water conservation - never requires addition of water
Acid encapsulation in the matting
Operation well below 0°F or -18 °C.
Availability of UL, DOT, CE, Coast Guard, and Mil-Spec approved types
Vibration resistance due to the sandwich construction.
[edit]
Disadvantages
Cost. AGM automobile batteries for example, are typically about twice the price of flooded-cell batteries in a given BCI size group.
AGM batteries have up to a 10 year lifespan, but must be sized to discharge less deeply than the traditional flooded batteries. For an AGM battery, the depth of discharge for optimal performance is 50% but flooded batteries can be rated up to 80% depth of discharge.
Yup - that lists the technical advantages over FLA... But only a few of them have a real world advantage for you - the end user. When was the last time you thought to yourself - hmmm, I really wish I had thicker lead plates in my battery so they were self supporting?
The dissadvantages impact significantly on "real world use"
Post #58657 4th Apr 2011 8:00am
Tomw2000
2011 Range Rover Vogue TDV8 Java Black
I'm sat at dealers now getting them to look at the battery issues with our MY11 tdv8.
Will update later...
Post #58668 4th Apr 2011 8:55am
I thought it worth reminding peeps about the benefit of a Solar Charger plugged into the bootspace 12v socket and positioned in a rear window (no tints)
This will keep the battery nicely topped up at all times but ONLY the boot space 12v is live with ignition off.
Mapilns Online 12.99
Post #58680 4th Apr 2011 10:38am
Tomw2000
Had a 'recoding' to stop the fans/blowers coming on randomly all the time. Will keep an eye out.
And erm, *ahem*, they didn't tell me there was an acknowledged problem and that once the software update was ready and the new batteries in better supply, they'll be doing a recall. No, they definitely didn't tell me that Wink
Post #58684 4th Apr 2011 11:06am
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
The boot socket does not work on the 2011 models unfortunately (after locking the vehicle) 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #58685 4th Apr 2011 11:15am
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
So now a £70k+ LR needs a £12.99 Solar Charger to keep it on the road Rolling with laughter
Sure this would go down well with the motoring press but as jez000 says it wont work on the 2011 MY vehicles so must pop off to the dealer to ask for an extention kit from one of the sockets that will Thumbs Up
Oh sorry there aint one Big Cry "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #58714 4th Apr 2011 4:01pm
Just checked and the 2008 model I have does work even when the car is locked but I guess you 2011 boys will have to get the new battery....
Post #58731 4th Apr 2011 5:51pm
AMV
2011 Range Rover Vogue TDV8 Santorini Black
Are you 100% sure?
If so that's really bad, I was planning to get a solar charger too Twisted Evil Santorini Black RR Vogue 4.4 TDV8
Post #58757 4th Apr 2011 7:33pm
Mine is plugged in at the moment in the boot of a 2008 TDV8 with the panel in the rear quarter light and I am really pleased with its simplicity and effectiveness!
Bargain of the year IMHO.
Gary
Post #58758 4th Apr 2011 7:36pm
Are you saying you cannot plug a fridge into a 2011 car boot socket and then lock it to go for a walk and have your picnic and beer on return......
Surely not Question Confused Shocked
Post #58759 4th Apr 2011 7:38pm
jez000
I used a phone charger in all the sockets and locked the car and they all powered down straight away Crying or Very sad 2021 P400 Silicon Silver AB
Post #58798 4th Apr 2011 9:23pm
What a dreadful state of affairs that you have to rely on a solar charger or battery conditioner to enable you to start your £70k car. Time LR got their ars3 into gear abd sorted the problem out
Post #58810 4th Apr 2011 9:36pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
You could never do that regardless because a range rover running a fridge would mean warm beer and no starting when you got back.. Laughing 2004 black Vogue TD6
Post #58836 4th Apr 2011 11:18pm
jez000
It would be interesting to see what they do with the battery on the Holland & Holland edition, they seem to have bigger RSE screens, a fridge etc ... 2021 P400 Silicon Silver AB
Post #58842 5th Apr 2011 6:20am
I did same with a phone charge lead that has a red LED to show power supply. In the boot socket it continues to glow red after superlocking the 2008 model.
It would be good if another 2010/11 owners tried same and posted results?
Post #58843 5th Apr 2011 6:43am
