![]() | Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 788 ![]() ![]() ![]() |
Mines a MY19 SDV8 VSE. Is that the FBH piping in the photo?
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Yes. Yours is a Webasto unit. Land Rover must have changed back to Webasto for the later L405s. Kev
Many thanks.
It'll be different, Phil. The part number earlier was for the Eberspächer receiver.
I’ve located the part number(s) on the FBH unit, any idea how to find out which receiver to match it with? Might it be one of these?
Hi Phil, I'm not sure to be honest. That receiver you linked to is the same as the one I had installed in my 2010 RRS and also fits in the L319 and L322.
Thanks Kev,
Where the BCM is on the right of your picture, you need to look/feel upwards into the D pillar. Kev
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
So is this not doable on the petrol L405? on the 2004 did you have to install the ducting etc to push the air into the cabin? As well as the module and the remote + coding? 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
This is the view up the D Pillar. A single large loom with a spur off for an interior boot light and also the small green box. Nothing else loose or taped as far as I can tell.
The existing heating ducts and climate control is used. You have no FBH so you have to see if you can install one. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
^^ I can't believe no one owning an l405 petrol hasn't tried installing this....I've literally found nothing on the internet. 2014 FF Autobiography 5.0 SC
capcgn Member Since: 21 Sep 2011 Location: Cologne Posts: 29 ![]() ![]() ![]() |
I tried to retrofit the remoute unit on my car. I have the heater ( exact as it is shown in the pictures) under the bonnet. But I dont have the cable under the rigth rear pillar. Instead I have a small loom what is connected to a TV unit ( antenna) and the boot lamp. I think the location for the remoute ECU has changed. Could one of you check if this is the case for the 2016 or LR has eliminated the loom to connect the remoute ECU and the antenna cable ? It would be great, I have now all needet parts and the ID tool and cant install the parts. Thanks in advance. |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 130 ![]() ![]() ![]() |
HI
