Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 129 |
Well the timed climate fan came on this morning but the diesel heater did not fire up but I think that was because it was not cold enough in the garage as I think its got to be under 5 centigrade so I have stuck it outside to have another go after its had a little chill. |
9th Feb 2021 11:01am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 221 |
The remote with HY32 as the prefix to the engineering part number is the Land Rover branded one as opposed to the CPLA prefix Range Rover one (which incidentally is double the list price of the LR one )
10th Feb 2021 8:15am |
10th Feb 2021 12:22pm |
The B12B2 error can be ignored as stated above, if the vehicle didn't have timed climate from the factory the valve isn't fitted.
10th Feb 2021 1:31pm |
Thanks again for your help I tried the remote again with my ear to the Heater and there was a small click when I pressed the remote so something is happening , is the connector C1HF01B in your latest diagram the same connector as C1HF06 on your diagram on page 4 as the connector C1HFO6 on my car looks the same as in the diagram on page 4 and goes to nothing it just has 2 open holes in the end of it.
10th Feb 2021 6:00pm |
Just to confuse matters connector C1HF06 and C1HF01B are the same size and shape.
10th Feb 2021 7:26pm |
10th Feb 2021 8:30pm |
Cutting the cable may well be easiest option, as you have found the pump connector is very well hidden.
10th Feb 2021 10:14pm |
PaulL405 Member Since: 08 Feb 2021 Location: Amersfoort Posts: 7 |
Hi, i have installed the remote and receiver! Thanks!
23rd Feb 2021 7:56pm |
spbee Member Since: 25 Jul 2021 Location: Cumbria Posts: 34 |
Ive just disassembled the D pillar in my 2015 vogue se and there are no connectors there on mine either :'( |
2nd Aug 2021 1:09pm |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
Just ordered the module and remote for mine, already done the CCF edit and got the timed climate option on the screen so just need to wait for the bits to turn up now. Then wait for cold weather
16th Aug 2021 12:39pm |
have you already confirmed the wiring is there ? |
16th Aug 2021 12:41pm |
Yes, found it tucked up behind the soundproofing Paul
16th Aug 2021 12:42pm |
Brill saves you installing it yourself |
16th Aug 2021 12:43pm |
