Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit |
marshallc Member Since: 16 Nov 2022 Location: Chicago Posts: 2 |
This thread was fascinating to me being us based, so I had to take a peek at my 2016 3.0tdv6. The hvac valve block/under hood section is the same on the US spec diesel variants; has the Eberspacher logo on the side like the OP's photo; but the small fuel line feeding the heater is absent lol!
16th Nov 2022 3:21am |
Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 48 |
Just completed this so easy, when you know how……. Thank you very much knWatkins for this write up!, its absolute perfect………just need a cold day now to test |
31st Dec 2022 2:39pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
No problem. Glad you found it useful Kev
2nd Jan 2023 6:50pm |
Llovatt Member Since: 07 Feb 2023 Location: Gloucester Posts: 1 |
Thanks for this write up. I have added all the bits but I can’t find anyone who can code it! What is the cheapest coding tool I can buy to do it myself? |
8th Feb 2023 11:12am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
rather than spend money on something you might only use once, give this chap a call..
8th Feb 2023 11:18am |
LukeSkywalker12 Member Since: 13 Dec 2023 Location: Nuerburg Posts: 2 |
Hi @ ALL !
13th Dec 2023 11:58am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 |
The LED indicator signals various states and conditions for the timed climate as follows:
13th Dec 2023 2:42pm |
Thanks, now I understand the remote control better ! |
14th Dec 2023 10:39am |
5c0tty Member Since: 07 Sep 2015 Location: Long Buckby Posts: 22 |
154JON did you manage to fix the issue with your pump? |
14th Sep 2024 6:39am |
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 61 |
If I already have timed climate can I just plug in a receiver (assuming the wiring is there), pair a remote and off I go? Or do I still need to update the CCF to reflect the receiver being present? |
20th Sep 2024 9:41am |
You will need to update the CCF files still, there is an option for remote
20th Sep 2024 9:47am |
Makes sense, thanks Scott. |
20th Sep 2024 10:09am |
I don't have my original build sheet or order forms or anything but I figured since I already had timed climate, it was worth taking a punt on buying a fob and seeing if it'd pair with the car, before buying a receiver as well. I'd have to buy a fob anyway if I had to retrofit a receiver so nothing to lose...
26th Sep 2024 2:03pm |
RRL405Ger Member Since: 11 Feb 2024 Location: Munich Posts: 4 |
Hello together,
6th Oct 2024 6:49pm |
