![]() | Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Yes, should be a 2 minute job now when the bits arrive |
I had it on my D4 and I think when the cold weather comes I would miss it too. Its nice not having to wait to defrost windows |
All done, fitted and programmed and wiring for the snow |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 131 ![]() ![]() ![]() |
Had all summer to sort my retro heating fit after i didnt getting it going last winter due to an open circuit on the aux water pump but i thought i would wait till i could stand in the cold again to try and sort it |
G3 TUC Member Since: 31 May 2021 Location: Cleethorpes Posts: 5 ![]() ![]() ![]() |
Hi all fitted the parts and paired remote but it will only work if am stood next to back piller any one any ideas as to why
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
Check the antenna connections |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
I don't get a very good range on mine to be honest. It's fine for my needs, and will work between my hallway and car, but if I move into my kitchen, it doesn't reach. On my old L320, the range was crazy. I could have been in the middle of the supermarket and it would reach out to the car park. Kev
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
This is bloody genius! Thank you, Kev. Will be checking if I have FBH and, if I do, I feel an upgrade coming on. What do I put here then? |
No problem |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
this any help?
This morning's frozen FF reminded me to at least do this bit. All looks good. Have set it to run tomorrow morning as a test. Assuming it works - can't see why it won't - I'll be buying the bits to add the remote. Thanks again for this @knwatkins it's a great post. What do I put here then? |
Ran my test timed climate this morning.
Strange. My windscreen is always defrosted by the time I get out to the car. Mind you, I think last night was particularly chilly. Just whack your heated front screen on. Should be melted in a few minutes |
My L322 used to always clear the screen too.
