Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit
Page 4 of 8 <12345678>
capcgn
Germany 2006 Range Rover Westminster 4.4 V8 Chawton White
I did search all the way up to the SRS module in the rigth rear pillar, no luck
Post #581335 27th Jan 2021 9:26am
knwatkins
Yes, they aren't the most obvious. As above, you need to do a bit of feeling around to locate and unwrap them. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #581337 27th Jan 2021 9:33am
capcgn
I have located the loom up to the SRS unit and it is not there. Im 100% sure
Post #581340 27th Jan 2021 9:38am
Phil.
If you do find the connectors please let us know as I am still keen to fit the remote unit too. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #581351 27th Jan 2021 10:11am
capcgn
Yes I will, maybe a pro can give me a instruction to remouve the D-pillar cover inside, so I can see if the loom is more up at the D- pillar. Thanks for help.....
Post #581353 27th Jan 2021 10:15am
capcgn
Update
I managed to remouve the inside D-pillar cover on the rigth side of my car. The loom is 100% not prepared to have the remout control unit there. No cables or antenna present. The location for the remoute control unit is occupied by the SRC unit. I think and hope, the location was changed to another place. Maybe one of you can check in the workshop manual for the location of the unit for 2016 and up models. Thank you. Bow down
Post #581479 28th Jan 2021 11:22am
knwatkins
The location is still the same on 2016 according to my manual. However, I think we have to conclude that your investigation has proven the wiring is not present. What are you referring to as the SRC unit? Supplementary Restraint Control?
 Kev
Post #581560 28th Jan 2021 10:07pm
capcgn
Thank you for the fast replay. The box behind the D-pillar in my car is to my undestanding from the airbag SRS ( Sorry not SRC ) It is wrapped in foam. No other cables or antenna connector are present.
Post #581580 29th Jan 2021 8:17am
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Before you go searching for the connectors in the D-pillar it is worth checking that the required wiring is present at the FBH power connector. If the vehicle is wired for radio-remote FBH operation there will be a thin brown/violet wire at pin 4 on the left hand side of connector C1HF01A shown in the picture below:
If the wiring is not fitted it may be possible to add remote control by tapping into the wiring from this connector to the FBH control unit. I've done this on my '17 and it works after modifying the CCF (note that on 17-on models this currently can only be done with a CCF editing program in conjunction with the JLR Pathfinder software), however for some reason even with the correct CCF settings I cannot get the timed heater options displayed.
Also note that without the water change-over valve connected (which is only fitted when park/remote park heating is specified in the build spec), the Automatic Temperature Control Module will generate a fault code, but this does not stop the operation of the FBH.
[Edited to correct mistake in colour code - sorry to anyone who was misled]
Post #581644 29th Jan 2021 4:28pm
capcgn
Thank you for your help. I checked and yes I do have the thinn brown cable with a blue stripe.
Post #581705 30th Jan 2021 8:56am
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Following with interest as I have had no luck finding the connectors
Will check for the thin brown/ blue cable Thumbs Up Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #581709 30th Jan 2021 9:06am
aljo
On this wiring diagram the wire from receiver is brown/ violet
[/img] Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #581716 30th Jan 2021 10:00am
Phil.
Mines the Webasto unit (MY19). Where should I be looking for the brown/violet wire?
 MY23 D350 HSE
Post #581756 30th Jan 2021 1:21pm
Fifth Horseman
Looking at the photo, I would say you need to look on the right hand side of the large grey connector next to the FBH. A word of caution, the later vehicles with the Webasto may have a different colour code, I've not seen any wiring diagrams for these - also my note earlier was wrong for the colour of the wire (must wear glasses more often Embarassed ) the wire you are looking for is Brown/Violet - the Brown/Blue one is for the heater fuel pump.
Post #581866 31st Jan 2021 8:34am
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Evening all just after any possible thoughts and help, today fitted a new receiver and updated CCF with IID tool and timer climate option came up on screen, tried several times but could not get the remote to pair, removed fuse 1 and put back after 10 seconds, held down off button but light went green then flashed red quite quickly which seems to mean no communication with the receiver, does the ignition need to be on or off when the fuse is removed and replaced. I have set the timed climate to come on in the morning for a single use to see if it will work that ways that likely to happen without the remote being paired and does the diesel heater make quite a noise and make it quite obvious when its running.
Thin brown and purple wire is present as is the diesel heater
Everything went quite numb after being out in the snow so another play tomorrow
Many thanks Big Cry
Post #582886 8th Feb 2021 9:01pm
