Home > Maintenance & Mods (L322) > My Battery Top Tips - Go AGM!
Page 3 of 4 <1234>
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Thanks. I don't have a GAP tool.
So should I assume I must replace like with like (i.e. non AGM) ? Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #548025 23rd Mar 2020 1:59pm
ur20v
A Trap
I would go AGM, I think it makes a huge difference on charging in the short term so you can either get a GAP tool or get your local Indy/dealer to set it for you at a later convenient date. The AGM’s are better.
Main proviso is types of journeys you do, you are a short hop, city/town driver definitely AGM, but if your regular commute/journeys are long save some money and go regular flooded lead acid.
Post #548026 23rd Mar 2020 2:07pm
cass
I treat batteries as a service item and decided to change the AGM battery on my 2011 TDV8. There was no sign of a problem but as we were approaching winter and it was at least 4 years old and possibly 8 years old it was a precautionary thing. The battery that I removed went onto my 2007 TDV8. I’ve known this car for years and it did sometimes suffer from a flat battery when used for short trips despite having had a new alternator and battery. So far this (admittedly mild) winter it has never failed to start.
This hardly a scientific test but it’s enough to convince me that an AGM battery is well worth the extra cost
Post #548029 23rd Mar 2020 2:22pm
cass
I should have added that I didn’t change any settings, just bolted the battery on
Post #548030 23rd Mar 2020 2:24pm
John w
Thanks.
The car was sat for about 3 weeks and that seemed to kill the battery.
I think a cell has died. I Put it on charge and think that has killed it further. Unlocked the car this morning but would not start, so left it.
When its used I do about 50 miles a day in it.
I think I will order an AGM battery then. Too many toys, not enough time
Post #548033 23rd Mar 2020 2:42pm
Baltic Blue
John,
The 2011 you own definitely needs an 019 AGM battery.
Post #548036 23rd Mar 2020 3:24pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Agreed Baltic Thumbs Up Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #548038 23rd Mar 2020 4:01pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, I have an 8-month-old AGM battery for sale which has been checked by GSF and is perfect when I tried to return it today?
This is because JLR told me in Spain it was at fault and I paid 309 euros for a new one.
Post #548045 23rd Mar 2020 4:44pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi all, just for info, bought my 07 4.4 petrol jag engined car in 2014, a few weeks ago the battery had a sudden death experience, just in front of my new indy. They took it out and it was an AGM OEM LR. Never had a problem with it and replaced it with a Varta AGM that has exactly the same dimensions. Turned the steering wheel from one side to the other and it works like a doll. 3 year waranty on the battery at a total cost of 240 euro fitting included.
Post #548052 23rd Mar 2020 6:44pm
Weegie
Who are you using, Robert? John
GAP iiD BT-Sold
Post #548053 23rd Mar 2020 6:58pm
Robert
John Davis in St Meard sur Drone, Mareuil tel 0681916970.
Didn't that address came from you?
Post #548073 23rd Mar 2020 9:47pm
Weegie
Yes that’s right. Hope you are pleased with him. Regards John
GAP iiD BT-Sold
Post #548076 23rd Mar 2020 10:20pm
John w
Rightly or wrongly, I went with a non AGM Bosch 5-013 (their 019) in the end (I had ordered it and picked up yesterday afternoon before I saw your comments Baltic & Bushy).
The reason being I don't have an IID tool to change anything, and it was a non AGM battery in there before that I was replacing, so this seemed the least risky choice to get the car usable again.
Add to that the new battery has a 5 year life, so if it proves to be crap and dies I will take it back.
I do suspect it should have had an AGM battery originally. If I still have the car in 5 years time maybe I will fit an AGM one then Smile Too many toys, not enough time
Post #548171 24th Mar 2020 8:38pm
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Just keep your receipt and keep the boot electronics dry including the silly rear wiper setup and you will be ok. I have changed a few batteries under warranty and if I were the manufacture I would give range rovers a wide berth!
Just had my AGM in my 03 td6 a couple of month too early to comment but I would say optimistic as it seems to recover from discharge well and have a higher voltage resulting in less cranking.
Post #548172 24th Mar 2020 8:49pm
Always
I'm the OP on this thread. Just feeding back with the final instalment of this battery's life... The AGM battery I fitted just over 3 1/2 years ago has reached the point where it is becoming unreliable so I've decided to swap it (for another AGM battery obviously!).
Some might say that 3 1/2 years isn't very long for one of these, but I know that my driving profile of lots of short journeys with all the heaters on and using the FBH regularly is a battery-killer, so I reckon 3 1/2 years of largely trouble-free service is pretty good going.
Lockdown didn't help... so I've had to charge it a couple of times in recent months, but all in all I'm very happy with the AGM battery decision.
Now... onto my sticking brakes issue... I'm off for a search...!
Cheers.
Post #591968 21st Apr 2021 9:10am
Page 3 of 4 <1234>
