![]() | Home > Maintenance & Mods (L322) > My Battery Top Tips - Go AGM! |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
I would go AGM, I think it makes a huge difference on charging in the short term so you can either get a GAP tool or get your local Indy/dealer to set it for you at a later convenient date. The AGM’s are better.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 749 ![]() ![]() |
I treat batteries as a service item and decided to change the AGM battery on my 2011 TDV8. There was no sign of a problem but as we were approaching winter and it was at least 4 years old and possibly 8 years old it was a precautionary thing. The battery that I removed went onto my 2007 TDV8. I’ve known this car for years and it did sometimes suffer from a flat battery when used for short trips despite having had a new alternator and battery. So far this (admittedly mild) winter it has never failed to start.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Thanks.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 ![]() ![]() ![]() |
John,
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Agreed Baltic |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1195 ![]() ![]() ![]() |
Hi, I have an 8-month-old AGM battery for sale which has been checked by GSF and is perfect when I tried to return it today?
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
Hi all, just for info, bought my 07 4.4 petrol jag engined car in 2014, a few weeks ago the battery had a sudden death experience, just in front of my new indy. They took it out and it was an AGM OEM LR. Never had a problem with it and replaced it with a Varta AGM that has exactly the same dimensions. Turned the steering wheel from one side to the other and it works like a doll. 3 year waranty on the battery at a total cost of 240 euro fitting included. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
Who are you using, Robert? John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
John Davis in St Meard sur Drone, Mareuil tel 0681916970.
Yes that’s right. Hope you are pleased with him. Regards John
Rightly or wrongly, I went with a non AGM Bosch 5-013 (their 019) in the end (I had ordered it and picked up yesterday afternoon before I saw your comments Baltic & Bushy).
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Just keep your receipt and keep the boot electronics dry including the silly rear wiper setup and you will be ok. I have changed a few batteries under warranty and if I were the manufacture I would give range rovers a wide berth!
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 54 ![]() ![]() |
I'm the OP on this thread. Just feeding back with the final instalment of this battery's life... The AGM battery I fitted just over 3 1/2 years ago has reached the point where it is becoming unreliable so I've decided to swap it (for another AGM battery obviously!).
