![]() | Home > Maintenance & Mods (L322) > My Battery Top Tips - Go AGM! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
And from what others have said on here, if your car was not designed to use an AGM battery, look forward to it dying on you in @ 18 months |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
Although, I believe you can change the battery type with an IIDTool, so the charging strategy it changed to suit. Got - 2017 SDV8 Autobiography in Loire Blue
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
I think the problem stems from the alternator charging at 14.4+v on some cars and that will overcharge an AGM battery on a long run think it has to have a lower charge rate of approx 13.7 so a variable charge rate is best from memory |
Some more info
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7896 ![]() ![]() ![]() |
I believe on the later L322’s with AGM as standard, you have to tell the car the battery is replaced. 2011 Range Rover Vogue SE 4.4 TDV8
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
AGMs take a HIGHER charging voltage. 14.6 to 14.8 is usual. |
You do indeed need to tell the car a new battery has been installed.
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Bloody crazy the situation, with the RR . I have had 2 x l322 diesels and both eat batteries. Varta well had two new fail, so on Exide now, and so far so good. I believe it's software related but no indy will know how to sort it. I left a new batt on a 1978 mgbgt went back 14 months later and it started we've gone a long way with auto electrics hey8 -) |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
How do you calibrate or tell the car that a new battery is installed can you do this with the IID TOOL if so how? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35608 ![]() ![]() |
you can do this on the 2010-2012my but i cant see an option on your 2006 year probably cos you wernt supposed to have agm batterys fitted on yours.... ... - .- -.
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
I'm about to replace my Varta L1 on my 2002 TD6, I'll probably do a dual install whilst I'm at it. My question is do I have to tell the fatty I've replaced the battery even though it'll be like for like or like for like +1?
just remember to set the steering parameters by turning the steering wheel fully left and then fully right after the battery re-connection... ... - .- -.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
ive always brought stealer batteries on advice from Craig and my indy pal and had three RR and brought new for every one and never an issue tbh and my mrs hammers the fbh,seats etc and used on short journeys often, had all on close on three years and still all seemed as fresh as day one so worth the extra cost imo |
Thanks for the reminder Stan. I'm assuming no IIDtool reset is required. |
