![]() | Home > Maintenance & Mods (L322) > My Battery Top Tips - Go AGM! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
nope |
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 54 ![]() ![]() |
Hi all.
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 ![]() ![]() ![]() |
My 2009 3.6 tdv8 has had a AGM battery for the past 3 years and touch wood no battery problems at all, so I agree AGM seems to be the way to go in my experience. I originally purchased a battery from europarts but it was too big and didn't fit, so i took it back and the only one they had was a Bosch AGM battery so they let me have that for the same price as the normal battery. I just fitted it and haven't had any low battery problems at all. 2009 Vogue SE Zermatt silver |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
i fitted an Odyssey PC1500 to my 2010 3.6 tdv8 and ran it like that for 2-3 years no problems.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I fitted a Century AGM in June. Recently I fitted a CTek plug to the battery which indicates if battery needs regarding. I do a short daily drive to the train station. I was warned this will impact on the battery. Looks like that’s true.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
I agree that 'any battery' is not suitable, at least as regards my 2010VSE.
Hi all.
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Interesting update, thanks.
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
So I have fitted a replacement AGM in my 11 4.4TDV8 and it starts perfectly etc. What I do have is difficulty with the FBH and the radio will only run for 15mins prior to shutting down with low power.
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
I wouldn't worry too much the AGM will take abuse much better than std lead acid. Since I went that route I notice battery terminal voltage is higher on start so results in firing up quicker, thus less drain. Ultimately the FF will work any battery hard and the essence is the ability of the AGM to tolerate deep discharge better without sulphating. Always keep my booster charger handy should be std fit on the FF. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
I have been away for 18 days, had to jump into the RR to get some supplies in, car started within a second . Did my trip 5 miles return, headlights and wipers on. RR back into my garage. Today I go to the garage and I have left the lights on for over 12 hours, jump into the RR and she fires up a usual instantly. I have a Deka Intimidator AGM battery that seems to thrive on abuse, cost more but seems to be worth it
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6760 ![]() ![]() ![]() |
Before I changed my alternator, I got a warranty replacement battery from ECP. I paid the difference and got the AGM equivalent.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
My battery is dying at present (wouldn't start this morning, despite being driven yesterday), so time for a change.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
From 2010 you can select the battery type and charge settings with a GAP iiD. Prior and you can’t and it should be a non-AGM lead acid battery. |
