Home > Technical (L322) > Restricted Performance? Could this be the culprit? - FIXED!
Page 1 of 4 1234>
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
As per my other post, been getting the Restricted Performance message coming up and only fault on the GAP IID is a high circuit egr code, which looks to be a red herring
Anyway, advice on here suggests an Restricted Performance error with no fault code is likely to be an air leak, and likely to be one of the four hoses under the engine cover.
So took the engine cover off just now and no signs of a split on them, so soot deposits etc. However the plastic connector that feeds to the main hose at the front, has a sensor plugged into it, that has what looks like a carbon build up around the clip.
Could this be the leak I’m looking for? If so how easy is that part to change and where best to get it from. I’m panicking a bit as I’m supposed to be taking some family down to see my elderly Dad in Cornwall over Xmas and this could scupper things
Post #537351 14th Dec 2019 10:05am
DrRob
I think Greg (GGDR) had exact same issue. Search his threads maybe. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537365 14th Dec 2019 12:24pm
DrRob
Also get those flimsy original 4 hoses replaced for the thicker ones
Think I replied to you on Facebook Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537366 14th Dec 2019 12:25pm
GGDR
Indeed looks same.
Mine took a while to find, so jump to the end:
https://www.fullfatrr.com/forum/topic52807.html
Or to save you reading the metal circle lost it's mojo and the intercooler to throttle body pipe was leaking (at the throttle body joint). Right where your soot is.
Soot = air leak thanks to the EGR. Separate topic but makes me think air filters are a bit pointless theory than keeping leaves and sand out.
The clip is not available separately so to save £200-odd quid, I bent it a bit more inwards and it's been a diamond since.
.. Cheers, Greg
Post #537367 14th Dec 2019 12:42pm
M@r]{
Oh right, so you had the same issue and it turned out to be a weak clip? But you can’t get a replacement clip?
Post #537368 14th Dec 2019 12:53pm
M@r]{
Just added a video to the original post. Should it have this much movement?
Post #537369 14th Dec 2019 1:07pm
GGDR
clip looks secure from your video.
my pipe just came off
but your soot? maybe a crack?
. Cheers, Greg
Post #537370 14th Dec 2019 1:26pm
GGDR
Mark can you clear your restricted with your IID ?
. Cheers, Greg
Post #537371 14th Dec 2019 1:29pm
M@r]{
This is why I should leave this stuff to the experts. Just removed that part to check for splits, cleaned it up, refitted and managed to break a water hose / clip. Now I’ve stranded the car. Ffs!
Any idea where I can get this from? Part of the plastic section is snapped off inside the pipe so not sure how I’ll get that out and if I’ll need a new pipe section too.
Post #537372 14th Dec 2019 1:45pm
GGDR
Oh god.
Well you're not the first, there are quite a few posts - I've not had the misfortutre but I think others have fixed it with a stent
. Cheers, Greg
Post #537373 14th Dec 2019 1:47pm
rjff
That part broken is only available with the hoses attached and is about £80, You may be able to get one from a breaker.
If you give me a few minutes I'll try and find the paperwork with the part number if I haven't binned it by mistake. Cheers
Richard
Gap IIDBT
Post #537374 14th Dec 2019 1:55pm
M@r]{
Would be great if you have. I can't believe this, this is the worst time for this to happen. I only had a look myself as I need the car back asap and hoped to find a straight forward fix. Now I can't even start the car let alone take it to a specialist. It is booked it to have a starter fitted on Friday too (another issue I've had)
Post #537375 14th Dec 2019 1:59pm
GGDR
I'm sure you can stent it to get you going for a day or two.
Search stent
Also here: https://www.fullfatrr.com/forum/topic48509.html?highlight=stent Cheers, Greg
Post #537376 14th Dec 2019 2:07pm
rjff
Part number on the invoice from Duckworth's is
LLR029140 but double check with the suppliers.
The rigid plastic hose that fits to that stub goes to a fitting with one of those press the blue tab in to remove type things, which is my technical term for quick release connectors. Whistle I would be careful removing as if you break that other end, then its the housing etc next. It may be an idea to source a pliable rather than rigid pipe of the same size to fit and use a couple of hose clips.
Let us know later today if you have sourced one. Perhaps Advanced Factors, site sponsor could assist on a Saturday afternoon. Cheers
Richard
Gap IIDBT
Post #537377 14th Dec 2019 2:16pm
Baltic Blue
http://www.fullfatrr.com/forum/topic48509.html
Good easy cheap fix here.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #537380 14th Dec 2019 2:40pm
Page 1 of 4 1234>
