Home > Technical (L322) > Restricted Performance? Could this be the culprit? - FIXED!
Page 2 of 4 <1234>
DrRob
Stent it as a short term fix and check it regularly.
Have the whole hose replaced ASAP. I had mine replaced as part of my preventative maintenance plan as it’s a very well known weak point Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537386 14th Dec 2019 3:28pm
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Tried cheap fix, couldn’t get the f type connector in. So need to revert to oem part
Thanks for posting that invoice. Which part do I need? The top one?
Post #537388 14th Dec 2019 3:39pm
DrRob
LR029140 on my invoice Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537389 14th Dec 2019 3:49pm
DrRob
https://www.island-4x4.co.uk/hose-genuine-lr029140-p-38388.html
Probably quicker to drop by your local main dealer ( Censored ) and get one. Ask for discount as you are a forum member Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537390 14th Dec 2019 3:52pm
M@r]{
Found one here, £85 inc delivery by Tuesday
https://www.ebay.co.uk/itm/RANGE-ROVER-TDV...3243958714
I'm sitting here SOOOOOOO p!ssed off right now. I'm so busy with work next week. I don't know when I'll have a chance to fit this, and to be honest I'm not sure I want to try after today shenanigans. But I can't move it so no choice really. And then I've still got the original problem to try to work out. Shortest ever honeymoon period with a car Big Cry
Post #537395 14th Dec 2019 4:06pm
rjff
It's quite easy to fit, don't bother trying to remove the broken part of the fitting, remove the hoses etc complete tomorrow. You can see where the part fits from the picture in the suppliers parts section and follow that through on the car. You're ready to go and it will take 30 minutes, which should include refilling whatever came out. In fact if you fill the system as far a possible you'll be ahead of the game.
Be CAREFUL with the right angle connector
Pobably telling the granny how to suck eggs. (not that I'm implying you're old Whistle ) Cheers
Richard
Gap IIDBT
Post #537400 14th Dec 2019 4:26pm
M@r]{
No, appreciated. My mechanical skills are limited to say the least. I should have left it alone, it's now cost me £85 plus a load of aggravation.
That right angle connector at the back of the engine? That does look flimsy. Is it easy enough to swap over?
And you think it is definitely better to swap the whole thing out rather than just the broken part? On first glance, the broken bit looks more easily accessible? The main hose seems to curl right under somewhere?
Post #537404 14th Dec 2019 4:32pm
DrRob
All been there. Hang in there, get all the bits done and it will be fine. Trust me, I’m a Dr Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537405 14th Dec 2019 4:34pm
DrRob
Have you got AA cover? See if they will come and do it Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537406 14th Dec 2019 4:35pm
mjdronfield
My connector broke whilst driving back in May. I managed to swap the pipes with the new part. Didn’t take that long.
I know you’re Censored ed off, but at least you have also had this known issue too....and aren’t miles from home.
Keep going!
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #537409 14th Dec 2019 4:43pm
Try cleaning the inlet manifold pressure sensor, the sensor you can easily get to on the top of the big plastic donut manifold. They can fill up with crud and read wrong hence you get a low pressure reading. There is nothing that can't be fixed with a hammer😜😜
Post #537411 14th Dec 2019 4:58pm
M@r]{
Thanks for the words of encouragement, I need it right now! Smile
Ref cleaning that sensor, I saw that mentioned on another thread and cleaned it earlier, it was completely blocked. Just couldn’t test whether it fixed the problem as I broke the water pipe :/
Anyway ordered that one on EBay, should be here Tuesday. I’ve also ordered 4 Samco silicon connectors, figuredneven if mine aren’t split and the cause, it’ll only be a matter of time.
Post #537414 14th Dec 2019 5:02pm
rjff
The right angle connector is fairly simple to remove, but if you have ANY worry, then you could carefully cut the hard plastice pipe off that connector and remove the broken piece from the other end, Then use a suitable piece of pipe from a car parts shop to fit in its place, secured with a couple of hose clips. That would let you simply change out the connetion piece that was broken.
That is, of course if Dr Rob's suggestion of the AA doesn't work. Cheers
Richard
Gap IIDBT
Post #537415 14th Dec 2019 5:06pm
DrRob
Have you swapped out your new top hose yet? Hope it went OK Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537785 18th Dec 2019 12:30pm
M@r]{
Yes did it last night under torch light! But yes went all ok. Car is booked in to a garage to have a new starter fitted and a smoke test, so hopefully will get an idea on what the issue is by the end of the week
Post #537810 18th Dec 2019 5:44pm
Page 2 of 4 <1234>
