Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module
Page 7 of 7 <1234567
mjdronfield
Good news then... I had a 6th gen, which worked fine with my iphone5 at the time.....if that helps anyone to get an idea of what gen works with what......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #421014 3rd Jan 2017 8:52pm
vinylmatt
Ireland 2004 Range Rover HSE Td6 Giverny Green
Baris wrote:
I do retrofit looms for the Bluetooth, if anyone is interested.
I haven't reached enough posts to message you, could you IM me about your loom?
Post #432928 28th Mar 2017 8:38am
Madmutt0
Loom wanted
Hi sorry too butt in but I'm after a loom as I don't fancy removing pins can yo pleas pm me barrs if you are still doing them thanks bob
Post #434686 12th Apr 2017 9:08am
ITSBIGSTE
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Hijacking the thread,
Ive scoured through what I can of the Bluetooth threads and am getting a bit confused with all the different posts and responses. I did find the list of BMW ULF numbers upto Gen13, but the post dates back to 2012.
So my question is, has anyone successfully fitted a newer model ULF?
& does anyone know the most recent compatible unit number please?
Many thanks, Steve (2006 4.2SC)
Post #442778 26th Jun 2017 5:16pm
mjdronfield
Gen 13 is the latest I believe. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #442789 26th Jun 2017 6:04pm
Baris
Just a heads up. I have finally cracked the Bluetooth ULFs and can upgrade them to Gen 13 versions. Should be ready in a few weeks, just need to do some thorough tests. barisahan@gmail.com
Post #470155 26th Feb 2018 2:39pm
p38arover
Australia
You're too far away! Big Cry Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #470196 26th Feb 2018 9:48pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Baris did you get ulf upgrade firmware sorted
Post #476508 22nd Apr 2018 10:12pm
Prebs
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Baris?
Did it work?
If so I would like to come visit you please 😎
Post #523654 3rd Aug 2019 7:40am
BarneyRubble
Australia 2002 Range Rover Vogue 4.4 V8 Barolo Black
Budgie wrote:
I attached a sort piece of wire to a scotchlock around the pin 36 wire. I then partly removed pin 32 and managed to get a stripped piece of wire onto the pin and pushed it back into place. I now have a double choccy block with pin 36 in one side and pin 32 in the other.
All I have to do for pairing is remove one of the wires from the choccy block and push it into the other side. Wink
I thought I had a switch hanging around that would have done the trick but I couldn't find it the other day. It'll turn up one day and get fitted. Very Happy
I have just completed this retrofit. Old thread but plenty of information that is just spot on.
I have a 2002 ffrr Vogue , 4.4V8. It was prewired with the 54pin plug and Bluetooth antenna cable in the rear and microphone wiring in the roof. Was also fitted with R/T and voice buttons on the wheel. No phone kit in console.
I purchased “MIT SES” ULF, antenna and microphone on eBay for about $90. 84106969268 - BMW E46 ULF Module(As per photo)
I pinned the 54 pin plug as per the diagram on this thread (prior to plugging in the ULF🤣). And connected it all up. Worked first time!!. Telephone came up on radio screen in white but could not enter the telephone prompt if enter button pushed.
I had issues in connecting to my iPhone 7s+.
I thought as this was an old thread I would just update the information.
The screen just kept displaying “activate phone”. The voice recognition worked and so did the microphone with the voice recognition. I soldered a wire to both pin 36 and 32 to enable pairing. I was unable to enter “Bluetooth pairing” no matter what I did. I tried putting a new wire in 32 and shorting to ULF case and still nothing. Every time I put the wires together, the voice recognition would activate.
I then read (very carefully) the thread again and bingo, it worked.
Probably not reiterated with enough emphasis that you must, with key off. Join 32 and 36 together, turn key on, go to back of car and disconnect joined wires straight away, within 1-2 seconds. It does not work using the steering wheel buttons.
All I need to do now is figure out phone book and text.
As said earlier, this is a great thread with really good, easy to follow instructions.
Great work to everyone who has contributed 👍
Post #602450 1st Aug 2021 12:50am
