![]() | Home > Technical (L322) > 4.2 Supercharged V8 Issues |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
Reasonably unusual for head gaskets to go on the supercharged engine, it happens, but make really sure that is your problem as it will be a big job - I might even consider taking the engine out as access will be one of the main issues you face. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1358 ![]() ![]() |
Check its not your lpg system passing gas from the reducer into the cooling system before you go pulling the heads off it .
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
i was thinking along the lines of the lpg system. i have never found a filler or switch over button or even the tank..... so i was going to rip it out any way... might try that first and do a full cooling system flush... |
Whoa
It was like that when we bought it. But definitely going for a full investigation to see if it’s a potential cause and cheap fix.
could be something as simple as an airlock in the cooling system if you have allowed it to go too low a level,
Roughly a moth ago we had the check coolant lvl message pop up, so we topped up an so forth. i bleed the system but found it was leaking from the bleed screw on the expansion tank....
ukadamwest Member Since: 22 Dec 2018 Location: Surrey Posts: 10 ![]() ![]() |
before you pull it apart. suspecting the HG pull the plugs are any steam cleaned? that would be a good test as would a compression test.
Sadly it is def the head gaskets possibly more,
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 ![]() ![]() ![]() |
There are some hoses under the intake/SC that probably should be renewed or at least checked thoroughly. 2006 Supercharged |
the idea is the replace all hoses probably go silicon for a bit of bling as its the wifes car |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 504 ![]() ![]() ![]() |
Sorry to hear of your problems with the 4.2 Matt.
HG'scan be quite daunting. take your time, follow the workshop manual and you'll do fine. the key is taking your time, its not going anywhere, don't rush it |
Hello,
