Home > Technical (L322) > 4.2 Supercharged V8 Issues |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Reasonably unusual for head gaskets to go on the supercharged engine, it happens, but make really sure that is your problem as it will be a big job - I might even consider taking the engine out as access will be one of the main issues you face. |
2nd Jun 2019 7:46am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Check its not your lpg system passing gas from the reducer into the cooling system before you go pulling the heads off it .
2nd Jun 2019 7:56am |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 |
i was thinking along the lines of the lpg system. i have never found a filler or switch over button or even the tank..... so i was going to rip it out any way... might try that first and do a full cooling system flush... |
2nd Jun 2019 1:20pm |
Whoa
2nd Jun 2019 1:56pm |
It was like that when we bought it. But definitely going for a full investigation to see if it’s a potential cause and cheap fix.
2nd Jun 2019 4:46pm |
could be something as simple as an airlock in the cooling system if you have allowed it to go too low a level,
2nd Jun 2019 5:17pm |
Roughly a moth ago we had the check coolant lvl message pop up, so we topped up an so forth. i bleed the system but found it was leaking from the bleed screw on the expansion tank....
2nd Jun 2019 6:07pm |
ukadamwest Member Since: 22 Dec 2018 Location: Surrey Posts: 10 |
before you pull it apart. suspecting the HG pull the plugs are any steam cleaned? that would be a good test as would a compression test.
5th Jun 2019 6:35pm |
Sadly it is def the head gaskets possibly more,
6th Jun 2019 12:05pm |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 |
There are some hoses under the intake/SC that probably should be renewed or at least checked thoroughly. 2006 Supercharged |
6th Jun 2019 12:22pm |
the idea is the replace all hoses probably go silicon for a bit of bling as its the wifes car |
6th Jun 2019 2:06pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
Sorry to hear of your problems with the 4.2 Matt.
6th Jun 2019 6:44pm |
HG'scan be quite daunting. take your time, follow the workshop manual and you'll do fine. the key is taking your time, its not going anywhere, don't rush it |
6th Jun 2019 10:43pm |
Hello,
12th Jun 2019 9:52am |
