Home > Technical (L322) > 4.2 Supercharged V8 Issues
Page 2 of 8 <12345678>
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Pretty sure if you are facing the front of the car you need to turn the nut on the viscous fan in an anticlockwise direction, having the right tool so you can hold the pulley helps alot.
Post #518150 12th Jun 2019 9:57am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
A viscous fan always unscrews in the direction of rotation.
Post #518226 12th Jun 2019 7:16pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
There is a free WM in the WIKI Thumbs Up Very Happy
Post #518231 12th Jun 2019 7:30pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Unfortunately i can not see the WM for the 4.2 Supercharged?
i will try smashing the fan in the opposite dirrection.
have tried knocking off in the clockwise direction stood in front of it.. will try the other way.
Post #518334 13th Jun 2019 3:01pm
Piet
Its in the Wiki, in the Wiki, scrol down to
DOWNLOAD & REPAIR VIDEO LINKS
Than click 2006-2010 workshop manual
Click the green download link on the page of Joe90, he found it.
Than go to page 303-00 4.2SC
Its there, Good luck
Post #518391 13th Jun 2019 8:09pm
MattHughes86
Found and now very scared....
but on a good note, we have the fan off bloody thing... got all the front mounted cooling items off... only one knackered bolt which was drilled out. (will remove stud later on when easier to get to)
now onto a side question. what is the best way to blank off a gas conversion that we have never used and doesnt seem to be commissioned?
Matt
Post #518451 14th Jun 2019 11:01am
cass
LPG - I would disconnect the wires from the tank solenoid then crack open a joint on the liquid pipe to release any pressure (obviously not in the boot of the the car, not in a confined area or close to an ignition source). Once the pressure has vented you're sorted.
If the line is full it may vent for ages, 1L of liquid creates something like 200L of gas
Post #518458 14th Jun 2019 1:00pm
MattHughes86
well the system is empty.
i just cracked the connector under the bonnett,
i have no idea where the tank is hidden on this thing? i can see one any where.
but there is a tank in the boot under the spare wheel which the spare also connects into?
but its not connected to the gas system that i can see.
it has either been on for ages or was a poor install in the first place as lots is loose and pipe crimp clamps are loose.
its now the onto the removal of wiring, then i get to figure out how to blank everything off and the water system re-route as well.
slow and steady, luckily its at work so i can potter on it through the day (when it stops raining that is)
Matt
Post #518468 14th Jun 2019 1:34pm
MattHughes86
Just a little update,
apart from what is attached the the gas injuectors, the whole front end water system is out, the gas parts are out....
next is to trace where this damn gas pipe goes to and then remove it along with the wire that runs along side,
who ever did this install it was not very good, so much of it was loose or connected in an odd way its a little bit worrying.
i think from the weight saved and the system getting blanked off thats got to be at least another 5hp lol.
 If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #518908 18th Jun 2019 2:46pm
Danwilderspin
What gas kit is it? May be interested in some parts ? Also is it a 4 hole tank? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519049 19th Jun 2019 9:29pm
MattHughes86
Sadly there is no tank installed, the piping terminates in the by the spare wheel.
as for the kit i have no idea, next time i got to the car i will get a couple of pics for you.
Matt If In Doubt Give It A Clout
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #519104 20th Jun 2019 1:59pm
Danwilderspin
no worries any idea why it was removed? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519106 20th Jun 2019 2:10pm
MattHughes86
since we bought the car it was never connected.
i wouldnt be suprised if some one was doing a home install on it then gave up.
there was so many fittings loose or not done properly, the wiring was done in a poor way.
but what items would you be looking for? If In Doubt Give It A Clout
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #519118 20th Jun 2019 3:26pm
Danwilderspin
It really depends on the kit tbh not interested in prins or anything polish after an aeb derivative ideally like king emer omvl bigas Romano and more cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519139 20th Jun 2019 5:32pm
MattHughes86
Wil get a few pics in a little bit.
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #519198 21st Jun 2019 7:59am
