Home > Technical (L322) > 4.2 Supercharged V8 Issues
Page 4 of 8 <12345678>
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
No problem. There's also a link in there to the part number for the timing locking kit if you still need one. Episode 3 if i recall correctly. 2006 4.2 SC
Post #531112 16th Oct 2019 1:56pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
currently on episode 2 laughing cause i remember how much of a ball ache half the stuff he has done. my heads are now off.
got to get them skimmed. but no apparent water issue found.....................................
time to check the block.
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #531231 17th Oct 2019 1:50pm
Spud
Pics of old gaskets removed? 2006 4.2 SC
Post #531269 17th Oct 2019 5:54pm
MattHughes86
here are the pics of the gaskets, one head had a blow by between cylinders, the only thing i can think is it was passing between the gasket?
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #531319 18th Oct 2019 12:53pm
Spud
Well. Bottom one looks fairly ok, but the top one is completely shot around the fire rings of pots 1 & 4 from what i can see. Good head skim with pressure test and a decent brand head set with mls gaskets and i reckon you'll be good to go. 2006 4.2 SC
Post #531351 18th Oct 2019 5:37pm
MattHughes86
have got the gasket kit on route, wife ordered it (at least if it fails i know what to do now) just have to clean the block up then the rebuild starts when they get here.
will comp test when back on as well
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #531388 19th Oct 2019 7:20am
Spud
Did you manage to locate a timing kit? 2006 4.2 SC
Post #531393 19th Oct 2019 7:46am
MattHughes86
yeah we got one for about £30 althought the label did say Lang Rover.
that is my biggest worrry is reseting the timing on the rebuild (fingers crossed)
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #531401 19th Oct 2019 9:07am
Sandyt
I have always used Elring gaskets on the p38 v8 and they have all performed well not the cheapest but ok
Post #531476 19th Oct 2019 5:52pm
MattHughes86
Hello all......
the rebuild has started (sorta)
im starting to get the heads ready to go back on (waiting on head bolts) but i thought i would check the tappets before getting back in the engine bay....
now they are way out all bar about 4
does any one know:
1. where i can order these from
2. a list/diagram of if out by this much add this tappet etc???
Cheers in advance
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #532006 24th Oct 2019 3:53pm
Danwilderspin
I might be wrong but if they are out a lot you need the valve seats doing on the heads.
Other option is to buy the oversized a ones and machine them down, the work manual says they make a couple of different sizes so I imagine dan can sort you out at duckworths Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532008 24th Oct 2019 3:57pm
MattHughes86
Hello all.
right so update, as i ahev the gasket set thought i would start to slowly re-assemble, have the intake bolted back onto the heads.
before i refitted them i thought lets double check the valve clearences... out of 32 valves i think 4 are withink spec.....
so i have worked everything out.... ordered 2 tappet/buckets as a tester to make sure my maths was right.
GET IN.... i got it right (or close enough anyway)
so i get on and work out the rest of the tappets need on my first line of vlaves, the plan is to change and entire set, move to the next and see if i can re-use any to save a few quid.
no the brick wall i have just hit is that i ordered LR037308, but this is now obsolete.....
does any one know how to cross refernce or jag engine parts to the one in the actual jag? or do i need to try something else?
Cheers for any help
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #535634 27th Nov 2019 2:26pm
MattHughes86
so next update.
i have found the jag part number came from the guys at lrparts.net.
very helpful
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #535656 27th Nov 2019 4:40pm
Danwilderspin
How is she coming along? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #541348 21st Jan 2020 10:42pm
MattHughes86
my wife has grown a child quicker than i have even got half way repairer this lol.....
the hang up has been the tappets, LR say that the parts are obsolete so having to source the jag versions, sadly this is taking time...
hopeing within the next week at least on head will be bolted back onto the engine, then will hit the other head hard,
our slow down is going to be parts avalability and the money for them..
but dont fear more photos will follow soon.
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #541367 22nd Jan 2020 9:07am
