![]() | Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
...that'll be a five sided torx as opposed to a normal six sided torx.. |
Yes, but with a hole in the centre, because their is a centre spigot in the head.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4321 ![]() ![]() ![]() |
I’m being thick...
It’s hard to lift out if you leave it connected |
rw90 Member Since: 07 Mar 2019 Location: Scotland Posts: 35 ![]() ![]() ![]() |
DrRob, I removed negative first then the positive. When reinstalling I did positive first. Just remember to wait the 120secs after turning off ignition.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 601 ![]() ![]() ![]() |
Just done this - great guide thanks.
Sorry I don’t know what E7 error is, but someone might enlighten us soon.
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
E7 is a general communication error (IIRC) -- I'd keep trying if I were you Current: 2011 FFRR Vogue SE 4.4 TDV8
Thanks guys. Had a run into Exeter today ~80 mile round trip. Found I needed to redo the auto on all of the windows. Lost the trip settings on the dash as well as date/time but obviously they're trivial to reset.
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Defiantly an AGM battery? Current: RR L322 2010
That's not an AGM, I'm running the same battery as it's what comes up in the list for the car from Halfords, and it has a 5 year guarantee.
You probably should research it a bit more but seem to recall something about that the agms charge at a higher voltage that can cause problems for older battery’s. May also invalidate your warranty. I would take it back to Halfords and demand the right battery for your vehicle. Current: RR L322 2010
I scoured the internet for the Best Buy and bought this one.
