Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Does this help?
11th Jan 2023 3:22pm |
SNDa180 Member Since: 07 Mar 2022 Location: Surrey Posts: 3 |
Thanks @jaygee, that does.
13th Jan 2023 1:55pm |
I 'think' the box behind contains the big fuses for the starter motor. Just looking at my picture I think I should put an insulator cover on that terminal. 2012 TDV8 Vogue (L322) |
13th Jan 2023 4:55pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
A = for the BMS
14th Jan 2023 8:01am |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 |
Hi all,
15th Jan 2023 11:32am |
If the Bosch doesn't have a vent hole then it doesn't need a vent tube. 2012 TDV8 Vogue (L322) |
15th Jan 2023 4:51pm |
Well I've checked with the supplier who confirmed that they do not require venting and therefore vent tube etc. isn't supplied.
16th Jan 2023 9:18am |
Richard2113 Member Since: 18 Mar 2021 Location: Banbury Posts: 6 |
Thank you to the original poster. A really great tutorial which helped me change my battery with no fuss. I have fitted a Bosch AGM to replace the Land Rover badged Varta. Bought from Tayna batteries who I have used before and recommend - good prices and rapid delivery. 2012 Range Rover L322 Westminster TDV8 |
28th Jan 2023 12:59pm |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 |
Thanks for all that usefull information. I have had a bit of luck today, I ordered a new Freelander 2 battery the other day for my daughter, and the supplier said they had a supply issue, would I take a similar battery. I said I would see if it would work, I now have a new super deluxe Rangerover battery! |
28th Jan 2023 7:29pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
Another video from Sam . Skip to 14:34
31st Jan 2023 10:30am |
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 30 |
Welp...I did my first read of this GREAT thread because my Turtle (Green 2012 US-spec Autobiography) almost made me call the tow truck for the first time. It looks like I have a battery issue and I'm going to have to figure out if it's the battery or a drain. Fortunatelly, I was able to half charge the battery using my Ctek charger and get home.
19th Jun 2023 6:48pm |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 |
Many thanks for the guide. Greatly simplified the task particularly the bonnet service position tip although I would recommend doing this with two of you as you really don't want to drop the bonnet with the rams detached at only one end. I found I was able to leave the ECU connected and haul it forward out of the way after removing the two screws that secure the loom going across the panel ahead of the ECU.
16th Dec 2023 11:25am |
Well I've been playing with the CCF battery type data for my vehicle, an 11MY TDV8.
17th Dec 2023 7:06pm |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 |
I have just changed my 2012 4.4 to an AGM battery, after the clicky starter motor issue. Absolute pain of a job, and without the 5 point torx it was hard to get everything tight, so I will get one of these off ebay and refit.
26th Jan 2024 4:22pm |
