Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4
Page 5 of 8 <12345678>
Baltic Blue
https://www.ebay.co.uk/itm/Long-Security-T...890.l49292
Lots on eBay Greg, but I think this is the set I bought.
Post #573740 22nd Nov 2020 3:50pm
TJRL
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
GGDR wrote:
Quote:
Remove this plate by undoing the two 5 point Torx Security Screws. (You probably won't have a tool for this, but they are available on Ebay.)
does anyone know the size (or a link) to the correct 5-point Torx Security Screws for the ECU ?
Cheers,
I already had a set of security Tork drivers but my bolts had been rounded off by someone in the past. Big Cry
So I just got my Dremel out and cut slots in the top of each bolt and removed with a standard screwdriver. Then replaced the bolts with normal hex-head bolts as there really is no need to use security or Torx bolts for this use and next time there will not be any issues for me or anyone else working on the car. Thumbs Up 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD Sad
1960 Land Rover SII SWB SW
2020 BMW R1250 RT LE
2021 Triton ST-125 (Monkey Bike)
Post #573741 22nd Nov 2020 4:13pm
GGDR
Many thanks guys.
The eh-hem 'other' RR site we don't talk about has a size mentioned:
Quote:
The tool is a security torx. TS-30 is the size. It's a 5 point star instead of the typical 6 point torx.
So going to order a TS-30 -sided
Thumbs Up Cheers, Greg
Post #573749 22nd Nov 2020 6:12pm
GGDR
Did mine today.
This is the correct security tool:
https://www.ebay.co.uk/itm/Trident-Socket-...2749.l2649
Interestingly, these bolts are for the plate whose only job seem to be to stop someone reaching the 10mm nut below. Slightly pointless and I did wonder if I would take the 300grams off the car and delight in the weight saving Laughing
Nino's plank had me thinking about 2x4 but I didn't have any trouble with access or reach. Yes it's heavy but didn't seem too bad.
. Cheers, Greg
Post #574421 28th Nov 2020 4:39pm
neilly
Great guide Thanks,
Used it today to change mine.
My top tip is that a swiss army knife corkscrew is perfect for undoing the bonnet gas strut clips, mine were being stubborn.
Used the GAP IID to reset for a new battery. Origial battery had doen 3191 hours and was manufactured in 2011, so cannot complain.
Although I could not find in the CCF an option for the EXIDE battery 90AH 850A that LR now sell as a replacement. Assuming the old Varta 95Ah 850A setting is OK to use as they are both AGM.
Cheers
Post #575057 4th Dec 2020 1:26pm
black Yvonne
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I went AGM!
Had the 322 4.4td serviced today and got them to pop on a AGM battery as the last one (2 years old) just wasn’t holding charge, dropping down to 12.3v, the smart charger went into auto recovery mode last night So bit the bullet.
They asked if it was start stop, I said no, but I still want it please.
Will let you know how I get on.
Had to have N/S active dinamics wire fixed too.
Brake fluid changed
My air on is slow to cool, they want to try a re-gas and check for leaks, failing that, compressor!
Rear screen was not working
Apart from that, not bad yey 2012 L322 VOGUE SE TDV8 cream leather
2003 Audi A2 1.6 FSI Sport heated leather
2019 Kawasaki J125 limited edition
2012 RR Evoque sold
2011 Audi A7 3.0 tdi Quattro sold
2007 Peugeot 407 coupe sold
2000 Peugeot 406 3.0 V6 estate sold
2000 Peugeot 306 cabriolet sold
2000 Audi A8 2.8 sport sold
1997 Jeep Grand Cherokee 4.0 sold
1997 Peugeot 406 saloon sold
1987 Citroen BX sold
1884 Lada Riva 1.3 saloon sun yellow sold
Post #575113 4th Dec 2020 10:22pm
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
Aircon slow to cool
You might want to look at this thread for your aircon problem.
https://www.fullfatrr.com/forum/topic43778-45.html RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #575349 7th Dec 2020 12:30pm
black Yvonne
Thanks for this.
Bigger than a simple re-gas eh!
Glad it’s a common problem, always reassures me when I see others with same problem.
Many thanks 2012 L322 VOGUE SE TDV8 cream leather
2012 RR Evoque sold
Post #575403 7th Dec 2020 7:41pm
black Yvonne
Re: I went AGM!
Brake fluid changed
Update on the AGM battery
It’s a fantastic fix!
Car stood for a good 10 days over Christmas then I knew I had to move it the next day so went with the smart charger to charge it up, it would usually be on 30% by now but the new battery was still on 70% so I think it would be fine to be left for 2 weeks! The old one would never do that. No issues to report with it as yet.
Will update again further down the line.
Phil 2012 L322 VOGUE SE TDV8 cream leather
2012 RR Evoque sold
Post #578724 6th Jan 2021 7:41pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Special Tool re Battery removal
Hi All
Fantastic write ups from every body! just to say that the security 5star tool is as posted by GGDR came today and fits. My battery is on charge at the moment to bring the charge backup but the feeling is a change is due. Not a good time to do it during a lockdown but I'll be ready when it is.
So thanks to all.
Dave
Post #580635 21st Jan 2021 12:21pm
Dean_C
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Great write up, very informative.
Have ordered Halfords agm 019 95amp with 850a cold cranking.
I don’t have the gap tool to reset unfortunately. Will see how it goes tomorrow.
Can anyone tell me why wait 120 seconds before removing battery terminals?
Oh & thanks for the tip regarding 10 mm bolt.
Post #601729 24th Jul 2021 9:01pm
DrRob
The 120sec delay is to give time for the ECU etc to shut down. Personally ids give it longer to play safe Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601730 24th Jul 2021 9:32pm
Dean_C
Thanks good to know
Post #601733 24th Jul 2021 9:55pm
Sean
England 2007 Range Rover Vogue SE TDV8 Java Black
Thanks great guide
Post #601734 24th Jul 2021 10:18pm
Caesium
Philip wrote:
Had the battery warning from new, dealers were useless - it would even give the “Start engine” message when you opened a door whilst a smart charger was connected.
Glad it’s not just me then. Mine says this with a charger or a stabilised 13v psu connected Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #612568 14th Nov 2021 12:17am
