![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Bank 1 MAF is constantly lagging behind. I’m not sure if it’s significant or not though.
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 696 ![]() ![]() |
MAF 1 i replaced with a new genuine MAF but it read the same and made no difference so I took it off and returned it.
Ok. Copy that
How difficult is it for you to get your EGR re map checked?
I can get the EGR remap checked but the valves themselves and the inlet manifold have physical blanking plugs installed so no exhaust gas would be able to enter the intake.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
I still think its a trans issue. Probably TC but could be simple flush and filter. When was it last changed. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Why for the majority of the test was the throttle on such a low opening%? Even right near the end it was only 40-50%. I expected to see quite wide openings at low revs showing low airflow indicating non-performance but the throttle generally was less than 20% open. |
Hi Graeme,
Right,
I still think that the throttle position sensor must be faulty as the throttle% never gets high unless basically 100%. |
The injectors and airflow seem ok, but as Graeme says, there’s something amiss with the throttle.
There is only 1 physical TPS but it is a twin system so I agree that a discrepancy would be expected to trigger a fault which would be the reason for having a twin system. However why does the 40-90% range not feature more prominently in the graphs? Is something restricting pedal movement that requires a lot of pressure to overcome, after which the pedal easily goes to full throttle? |
Copy that Graeme.
Hi Cheezels,
