![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2661 ![]() ![]() |
Sounds similar behaviour to my previous TD5 D2 when the MAP sensor became very clogged. Only use a spray cleaner inside a MAP sensor because solid objects such as wire risks damaging the sensor. Your engine has 2 MAP sensors. |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 738 ![]() ![]() |
I did try cleaning the map sensors back in December however I would imagine at least the o/s one will be contaminated with oil again due to the turbo.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Injectors need a clean would be my guess.
Hi Grofus,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
inlet manifold cracked?? |
I have considered a possible cracked inlet manifold Stan. Would this give me codes though as the MAPs wouldnt be reading correctly?
Ok so i removed and cleaned both MAP sensors. The left hand one was very oily as expected. I also cleaned the intercooler pipe on this side of residual oil.
Things are getting interesting.. RR driving crap again this morning so decided to repeat exactly what I did last night.
Another small update,
Cleaning the MAFs would be appropriate although if you have an IIDTool then you could compare airflow readings and compare left and right boost too. |
It's not unheard for one of the lower turbo hoses to fail. There are 6 in total. 2 are short near the turbo and 2 longer to the intercooler and the 2 top ones that always fail. You can normally hear a boost leak.
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Cracked inlet manifold gives turbo boost pressure faults.
Thanks again all for your suggestions.
