Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Bank 1 MAF is constantly lagging behind. I’m not sure if it’s significant or not though.
27th Mar 2019 9:58am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 678 |
MAF 1 i replaced with a new genuine MAF but it read the same and made no difference so I took it off and returned it.
27th Mar 2019 10:03am |
Ok. Copy that
27th Mar 2019 11:31am |
How difficult is it for you to get your EGR re map checked?
27th Mar 2019 12:09pm |
I can get the EGR remap checked but the valves themselves and the inlet manifold have physical blanking plugs installed so no exhaust gas would be able to enter the intake.
27th Mar 2019 12:50pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
I still think its a trans issue. Probably TC but could be simple flush and filter. When was it last changed. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
27th Mar 2019 1:39pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2495 |
Why for the majority of the test was the throttle on such a low opening%? Even right near the end it was only 40-50%. I expected to see quite wide openings at low revs showing low airflow indicating non-performance but the throttle generally was less than 20% open. |
27th Mar 2019 8:14pm |
Hi Graeme,
27th Mar 2019 9:40pm |
Right,
27th Mar 2019 9:42pm |
I still think that the throttle position sensor must be faulty as the throttle% never gets high unless basically 100%. |
27th Mar 2019 11:47pm |
The injectors and airflow seem ok, but as Graeme says, there’s something amiss with the throttle.
28th Mar 2019 10:54am |
There is only 1 physical TPS but it is a twin system so I agree that a discrepancy would be expected to trigger a fault which would be the reason for having a twin system. However why does the 40-90% range not feature more prominently in the graphs? Is something restricting pedal movement that requires a lot of pressure to overcome, after which the pedal easily goes to full throttle? |
28th Mar 2019 11:49am |
Copy that Graeme.
28th Mar 2019 12:05pm |
Hi Cheezels,
28th Mar 2019 12:45pm |
