![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Interesting. If I unplug my EGRs, I get a check engine light. Same for my mates TDV8. 2007 3.6 TDV8 |
Is your iid tool storing any pending faults? 2007 3.6 TDV8 |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
I have had my 2008 3.6 EGRs blanked for a couple of months including some long trips and, so far, no EML. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 737 ![]() ![]() |
Had a thought last night, I fitted led number plate bulbs to both cars.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2661 ![]() ![]() |
Silicone hoses are harder to tighten than the standard rubber ones. |
This new car has genuine LR hoses fitted Graeme, purchased 3 days ago to see if they would make a difference.
Are you saying the problem is solved?
No not solved Cheezels. Only lasted 6 miles!
Could there possibly be a problem with the intercooler rather than just the hoses? I know you have tested for leaks but just wondered if the problem might be John
Possibly, this is actually a completely different car I'm talking about now to the one originally discussed in this post.
Tried a few things again last night.
Have you traced where the temperature sensor loom goes in case its getting bumped when changing the hoses? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
Yes, but you seem unwilling to try them... ![]() |
Try -
