Home > Technical (L322) > 4.4 TDV8 MAP sensor
Page 7 of 10 <12345678910>
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
OK Nino.That can get oily through the turbo's.Should not be to dirty as it is before the dirty EGR air.The I/C should stop most dirt(oil)?If a lot of oil on the sensor then one of the turbo's seals are leaking!
Frans 2012 TDV8 Vogue SE 4.4
Post #444220 11th Jul 2017 12:47pm
nino_nino
you are right Frans, but after the MAP, no sensor is safe from me, i see it I clean It. Laughing Laughing
Post #444223 11th Jul 2017 1:38pm
Frans@Yamorna
Agree,will clean that sensor this weekend Very Happy 2012 TDV8 Vogue SE 4.4
Post #444229 11th Jul 2017 2:43pm
DrRob
Am I right in assuming the following....
The MAP sits on top of the inlet manifold and can be easily removed and cleaned?
The MAF sits inside the intake pipe and takes a bit more work to access?
This thread discusses both so I just wanted to check Thumbs Up
Thanks in andvance
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490393 30th Sep 2018 8:13am
rjff
Rob
You are correct in this. I have just replaced the four hoses and cleaned up the plenum and sensors. Filthy job. I did not take the MAF from the intake duct, as it looks as if it may be stuck in there. Rather cleaned with electrical cleaner. If you are only cleaning sensors the intake comes off fairly easily with a little care. Cheers
Richard
Gap IIDBT
Post #490401 30th Sep 2018 8:59am
DrRob
Is there an idiots guide on here for removing intake and MAF cleaning?
Can only see MAP cleaning Whistle
Going to clean MAP later Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490411 30th Sep 2018 11:38am
rjff
Embarassed Edited as may be an incorrect sensor ID please see Wiki under
tdv8 4.4 MAP & charge air temp sensors (MY11) cleaning process
Hope this helps
Remove the cover from the engine top.
In photo
remove hose clips 1 &2 and hose being particularly careful to avoid moving or damaging 3 & 3a
remove hose clip 4 and slide hose off
remove MAF connector 5, press at rear to release clip and remove, again with care.
clip 6 needs to be released by moving ends apart and easing out of grooves.
carefully ease away the plastic section containing the MAF
Clean and replace in the reverse order. Electrical contact cleaner did the job for me. The MAF is most likely a fragile device, treat with respect.
As a precaution, inspect the joint 3a for any signs of leakage of coolant, visible with a pink tinge. Replace the section. It appears to be only available as an £80+ part, although there is a repair, done I think be nino-nino.
Break the connector 3 and you're in for a bill of £40+ unless you can source a correct sized connector from the interwebs thingy. Cheers
Richard
Gap IIDBT
Post #490428 30th Sep 2018 4:04pm
DrRob
Excellent! Thanks Richard Thumbs Up
Love this forum Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490447 30th Sep 2018 6:28pm
GGDR
Looks like a Wiki right there!
Great work rjff!
. Cheers, Greg
Post #490452 30th Sep 2018 6:46pm
tis in the wiki, thanks rjff Thumbs Up
Post #490459 30th Sep 2018 7:48pm
DrRob
Nice one Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490463 30th Sep 2018 8:17pm
rjff
Rob you are welcome and I hope it helps.
gonna_go and Stan, thank you for suggesting and making this a Wiki. Cheers
Richard
Gap IIDBT
Post #490466 30th Sep 2018 8:32pm
DrRob
Thanks Stan Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #490470 30th Sep 2018 8:53pm
GraemeS
Hey guys, the MAFs are at the air-boxes!
Post #490475 30th Sep 2018 9:22pm
rjff
Hi Graeme
We've been looking at what we believe is the MAF in the outlet from the intercooler to the inlet plenum for the engine. It may well be only one of a series of sensors in the air flow monitoring and those in the air boxes may be measuring the difference in inlet flows between the first and second turbos, thus allowing the software to do its magic in calculating for fuelling etc..
Can you let us know what the parts name/sensor/number is and does and if it becomes contaminated in the same way as the one we are discussing? Taking them out for cleaning should not be a difficult job as they sit on top of the air filter boxes, rather in the way of the MAP in the plenum "donut" Cheers
Richard
Gap IIDBT
Post #490480 30th Sep 2018 10:14pm
