![]() | Home > Technical (L322) > 4.4 TDV8 MAP sensor |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Thanks for clearing that up for us. My mistake. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
Oil wont cause a sensor to misread whereas a MAP sensor blocked by carbon caused by oil + exhaust gas can cause the sensor to misread. |
Yep my MAP sensor was rather blocked and contaminated as you suggest.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
MAP is in the doughnut and MAF is in the main intercooler feed hose....that’s how I remember it |
Whilst the 2012 version of Microcat doesn't show the sensor in the I/C to throttle body hose, the wiring schematic shows the sensor as Sensor - Temperature - Air Charge. as I expected. |
Thanks Graeme
Thanks Rjff. It sounds as though the sensor is bonded in place which would explain why it isn't listed in Microcat. |
Evening Graeme,
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
The sensor is air temperature/density sensor and is a part of hose that attaches to the throttle body.
Thanks Nino |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
Pulled mine out yesterday and it was also covered in dry soot , quick blast with brake cleaner , leave to dry and back in , can't report on how it drives as the other half is using it but she's off for a long drive down to Minehead at the weekend so I'll reset the trip and see if it makes any diff to fuel usage . |
rw90 Member Since: 07 Mar 2019 Location: Scotland Posts: 35 ![]() ![]() ![]() |
Spent this afternoon doing this cleaning. The doughnut manifold comes out quite easily if you remove the large cabin air filter section at the bottom of the windscreen - it's only held on with 2 nuts.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I've been reading (elsewhere)you shouldn't use brake cleaner on MAF/Ps
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
I use electronic contact cleaner.Designed for that!! 2012 TDV8 Vogue SE 4.4 |
