![]() | Home > Technical (L322) > 4.4 TDV8 MAP sensor |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35615 ![]() ![]() |
after cleaning mine i went on a short rather slowish journey today and mine 'seems' smoother .. ... - .- -.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
it would be nice if all of as that have cleaned the sensors pay attention to the way the car drives in the next few days - to see if my theory has any merit. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
I took my son to the airport very early this morning (about a 18mile each way motorway) trip.
that makes sense Mike... |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Well all back together now and cleaned as well. I used half a roll of kitchen paper cleaning things so gungy!!
Stu,
G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Thanks Mike, I will keep to the speed limits as ever when I regenerate on Monday, I will lower the revs a bit this time but still keep them up a bit.. |
Cleaned the MAF and MAP sensors.The car is very responsive....is it better???difficult to say!!!No hesitation at 120-130km/u |
Well hopefully finishing my saga off today. DPF cleared itself within 5 mins or so this morning and no restricted performance on the way to work. Read faults at work, cleared them, drove home tonight smooth as you like, read faults when I got home and nothing. So all stripped cleaned and no faults. Happy bunny today! Current: TDV8 (3.6) RRS HSE
Well done Stu.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
Cleaned the MAF last night, was actually not that bad. So I now have a set of clean sensors. Will see how it goes!! There is nothing that can't be fixed with a hammer😜😜
The MAF sits in the air just after the aircleaner so it should not be dirty |
frans i was referring to this sensor:
