![]() | Home > Technical (L322) > 4.4 TDV8 MAP sensor |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
you are right Frans, but after the MAP, no sensor is safe from me, i see it I clean It. |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Agree,will clean that sensor this weekend |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Am I right in assuming the following....
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Rob
Is there an idiots guide on here for removing intake and MAF cleaning?
Hope this helps Remove the cover from the engine top. In photo remove hose clips 1 &2 and hose being particularly careful to avoid moving or damaging 3 & 3a remove hose clip 4 and slide hose off remove MAF connector 5, press at rear to release clip and remove, again with care. clip 6 needs to be released by moving ends apart and easing out of grooves. carefully ease away the plastic section containing the MAF Clean and replace in the reverse order. Electrical contact cleaner did the job for me. The MAF is most likely a fragile device, treat with respect. As a precaution, inspect the joint 3a for any signs of leakage of coolant, visible with a pink tinge. Replace the section. It appears to be only available as an £80+ part, although there is a repair, done I think be nino-nino. Break the connector 3 and you're in for a bill of £40+ unless you can source a correct sized connector from the interwebs thingy. Cheers Richard (there are no such things as an ordinary FullFat, an ordinary cat or too many tools) 2011 TDV8 Vogue Santorini Black Gap IIDBT Last edited by rjff on 3rd Oct 2018 7:57am. Edited 1 time in total |
Excellent! Thanks Richard |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Looks like a Wiki right there!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
tis in the wiki, thanks rjff |
Nice one |
Rob you are welcome and I hope it helps.
Thanks Stan ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
Hey guys, the MAFs are at the air-boxes! |
Hi Graeme
