Home > Technical (L322) > Reduced Performance
Page 3 of 4 <1234>
stu
Well the FF is stripped down, bit of a learning curve figuring out what needs to come off and some tools needed that some may not have, namely the tiny 1/4" drive tore socket needed to remove the four screws that hold the front of the manifold in place. The engine cover locating posts screw on to two of these, quite clever.
Anyway the long and the short of it is one of the rubbers is split! Hopefully this is the cause of all my troubles! As everyone else's everything is oily and dirty. Will clean before re assembly.
 Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443704 6th Jul 2017 12:32pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
stu wrote:
Just an update, I have been doing ping pong emails with Patrick @ GAP over the last couple of days. Thanks to his fabulous IID tool and his knowledge I now have the tool set up as he recommended and it is at last picking up the fault for my restricted performance issue and it looks like it will be an air leak on the inlet after all. Be ripping the FF to bits tomorrow and trying to find the culprit.
What are the settings to achieve this? Ive had the restricted performance appear during a spirited overtake, it's cleared itself and there were no codes with IID tool.
J BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #486799 22nd Aug 2018 5:08am
GGDR
AJGalaxy2012 I'm not even sure you need an IIDTool for this one, I'd check your hoses, they are known to do this, under the same circumstances (e.g. heavy acceleration /restricted / back to normal).
I believe there are newer, revised material hoses because of this.
Good luck! Thumbs Up Cheers, Greg
Post #486802 22nd Aug 2018 7:16am
AJGalaxy2012
Thanks I'll have a good look round over the weekend.
Post #486805 22nd Aug 2018 7:34am
GGDR
Note the fine split on stu's first pic.
Might not be apparent unless you remove the clips to have a good look...
. Cheers, Greg
Post #486806 22nd Aug 2018 7:39am
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Also worth checking that the plastic inlet manifold hasn’t split. This happened to my 4.4 TDV8 whilst in France 2 years ago. Same symptoms with reduced performance warning. The ID tool showed a temperature sensor fault, this was changed but the problem still remained. The French LR mechanic then found a crack in the manifold. This was replaced and the problem went away. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #486817 22nd Aug 2018 8:54am
gettingold
Wow that's a lot of gunk. You get the same thing on the Volvo S60/V70 D5 engines, if the owner is not aware of this the gunk can virtually fill the bore of the pipe.
Steve.
Post #486821 22nd Aug 2018 9:39am
AJGalaxy2012
Is this likely to be caused by hoses or something more sinister. It occurs when the pedal is down and the engine is working eg overtake, there is grey smoke in the mirror, almost looks like dust?
PCM-Engine TDV8
P0438-00 (27) Catalyst temperature sensor - circuit high (bank 2, sensor circuit 1)
( on 23-08-2018 10:04:52 at 200090 km
Your comments appreciated. BMW i3 Electric Car
Post #486897 23rd Aug 2018 10:26am
GGDR
The smoke could be caused by the (lack of) Turbo Drain Mod. This won't throw up an error but it's main symptom is smoke when the second turbo spools up, which is above 2000rpm.
Suggest you take off the hoses and inspect carefully as this also won't throw up an error, will just give the restricted waring then go away again.
. Cheers, Greg
Post #486898 23rd Aug 2018 10:53am
AJGalaxy2012
Today I had the chance to try and cause the limited performance to happen and Ive now repeated the same test twice.
Drive for 20 miles nice and steady, gentle acceleration etc. Then let rip on a dual carriageway feeding the throttle in down to the floor. Car following and I could see in the mirror considerable amounts of Blue Smoke (oil type smoke). On the second repeat of the above the exact same result but no restricted performance.
The smoke completely clears after about 50 seconds, you can slow down use kickdown and everything is good. Does it sound like it needs the drain mod doing? BMW i3 Electric Car
Post #487149 25th Aug 2018 9:01pm
Baltic Blue
Mine was very similar to what you describe.
It always belched out a cloud of thick blue smoke every time I floored it to pass slower moving traffic, particularly lorries on motorways, but it didn’t trip into restricted performance.
Since I have had the mod done I haven’t seen a trace of smoke under any driving conditions, and when I took it for it’s MOT recently the tester did the smoke test twice which involved him revving the engine after it had been ticking over a while, but each time he got a zero reading.
Post #487152 25th Aug 2018 9:57pm
AJGalaxy2012
Is this something an independent garage can do or best left to a main dealer? What sort of costs are involved parts and labour etc?
I do have a warranty from the seller so hopefully it will be ok. BMW i3 Electric Car
Post #487163 26th Aug 2018 4:35am
GGDR
is it a LR warranty?
Costs around £1000. Cheers, Greg
Post #487164 26th Aug 2018 7:53am
Baltic Blue
A couple of old posts suggest Independent ‘s quote around £1k to do the mod.
Personally I would try and find one who has done one before and fully understands what’s involved, even if it costs a little more. Mike.
PS The full TSB is in the Wiki with very detailed instructions. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #487165 26th Aug 2018 8:00am
AJGalaxy2012
Costs around £1000.
No it's an independent dealer type warranty, I'll see what he has to say. BMW i3 Electric Car
Post #487168 26th Aug 2018 8:30am
Page 3 of 4 <1234>
