![]() | Home > Technical (L322) > Reduced Performance |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
What are the settings to achieve this? Ive had the restricted performance appear during a spirited overtake, it's cleared itself and there were no codes with IID tool. J BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
AJGalaxy2012 I'm not even sure you need an IIDTool for this one, I'd check your hoses, they are known to do this, under the same circumstances (e.g. heavy acceleration /restricted / back to normal).
Thanks I'll have a good look round over the weekend.
Note the fine split on stu's first pic.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Also worth checking that the plastic inlet manifold hasn’t split. This happened to my 4.4 TDV8 whilst in France 2 years ago. Same symptoms with reduced performance warning. The ID tool showed a temperature sensor fault, this was changed but the problem still remained. The French LR mechanic then found a crack in the manifold. This was replaced and the problem went away. 2019 L405 SDV8 Autobiography
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 ![]() ![]() |
Wow that's a lot of gunk. You get the same thing on the Volvo S60/V70 D5 engines, if the owner is not aware of this the gunk can virtually fill the bore of the pipe.
Is this likely to be caused by hoses or something more sinister. It occurs when the pedal is down and the engine is working eg overtake, there is grey smoke in the mirror, almost looks like dust?
The smoke could be caused by the (lack of) Turbo Drain Mod. This won't throw up an error but it's main symptom is smoke when the second turbo spools up, which is above 2000rpm.
Today I had the chance to try and cause the limited performance to happen and Ive now repeated the same test twice.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Mine was very similar to what you describe.
Is this something an independent garage can do or best left to a main dealer? What sort of costs are involved parts and labour etc?
is it a LR warranty?
A couple of old posts suggest Independent ‘s quote around £1k to do the mod.
No it's an independent dealer type warranty, I'll see what he has to say. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
