![]() | Home > Technical (L322) > Reduced Performance |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Thanks Baltic Blue, I have the bulletin and it does look a bit involved so I will leave it to a competent garage, probably a main dealer. BMW i3 Electric Car
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
I agree totally with NMJ, but I would just add that several plastic plenum manifolds have suffered hair line cracks, which gives the same reduced performance problem.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
^ and what Mike said... |
Hi Guys,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
yes driving gently for a few days can cause the oil to build up as NMJ describes.
Yes I have limited (time) warranty and I can get the work done if it's needed. Ive already sorted a few issues out myself at my expense (towbar wiring, tow bar, parking sensors and a broken wire on air quality sensor) so im sure he will play ball if this work is needed. I'll drive it for a couple of days using the gas pedal a little more just to keep using above 2000 momentarily and see how it goes.
Greg,
I have no problem taking car dealers or warranty companies to court, I've done it about 7 or 8 times now and won every time. They'd have a very difficult time in court explaining that blue oil smoke was not a fault especially in the light of the modification kit available from Land Rover to cure the problem. Hopefully it wont come to that if I modify my driving a little.
Yep. That will do it.
I went for a little drive this afternoon, about 40 miles round trip, it's very difficult to spend any time North of 2000 RPM. When I did give it some wellie on the way back there was a slight haze of blue smoke that cleared in about 3 seconds. After that when I repeated the boot treatment the exhaust was clear.
My opinion, for what is worth, |
completely agree with Mike!
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
There is a lot to be said for giving your car a regular Italian tune up diesel or not.
