Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor?
Page 4 of 15 <123 45 ... 131415>
GraemeS
I would expect the hottest sensor to be after the cat so maybe swap 2 and 3 in my suggestions.
I'll see which sensor my manifold-only Euro 4 version shows later today.
Post #485766 11th Aug 2018 8:56pm
nino_nino
,this is from my afternoon run, sensor that reads 100 on your car was at 360C just before i snapped the picture.
note the rpm,s on the bottom. take the car to nice stretch of rod, put transmission in "S" and drive with revs over 2500 rpm for a few minutes. this way you can check if the sensor is operating properly.
Nino,
Post #485767 11th Aug 2018 9:14pm
GraemeS
My Euro4 engine shows 100 deg C for all 4 EGT sensors after a run and the P040D-00(2F) fault, if cleared, returns once the engine is started. I'll see if anyone else here can list theirs.
The EGR temp sensor isn't listed for live values but I don't think that is because of the fault as the 3 non-existent EGT sensors and the DPF pressure sensors are listed.
Update - s/b 4 exhaust EGT sensors
Post #485865 13th Aug 2018 12:15am
GraemeS
Manifold EGT sensor is EGR sensor A?
I've just found a 5th EGT sensor - I initially missed the one behind the DPF.
I note that the electrical wiring schematic, after applying a correction document, shows an EGR inlet temp sensor and an EGR outlet temp sensor but not the manifold EGT sensor. I suspect that the 4 EGT sensors are all in the exhaust system and the manifold sensor is the EGR inlet sensor. This would correlate with bank1 sensors all being primarily from the bank with the primary turbo and the bank2 sensor in the secondary turbo exhaust pipe and that there are 2 EGR sensors, with the egr inlet temp sensor located in the manifold and aligning with the DTC description of EGR temp sensor A.
Edit: It appears that the IIDtool does not show live values for the EGR temperature sensors so I have contacted GAP.
Post #485866 13th Aug 2018 4:16am
GGDR
Graeme, I was just typing to say I think there are 5 EGT sensors too!
This is my DPF / exhaust off the car:
The Cat is just in front of the DPF< still on the car.
There are 3 sensors in this section, before and after the DPF and one top right which is soon after Turbo #2
I've also emailed GAP asking how the numbered sensors on the IIDTool can be identified.
Let's just say the sensor in the NS manifold is Bank 1 Sensor 1 - then the temps "seem" to be reading ok. I will probably replace it anyway based on Craig's advice - but I don't have any reading to confirm it's faulty.
I also don't know how it relates to the P040D-00(2F) EGR temp sensor A error. My theory of a typo is fading.
This is what Craig said on another P040D thread:
Quote:
Depending how the temp probe fails, depends on what message it sends the ECU...
The reason behind the over fuelling is the probe reports back cold and opens the EGR and cold running cycle to the injection system??? (like a choke on a petrol) hence the over fueling and filling the DPF system/restricted performance etc etc
Others say:
Quote:
You can ignore the code P040D-00 it never clears and been told/shown that the LR diags show it as a historical fault that clears and then come back. it is due to the tight tolerances of the ECU against that sensor.
. Cheers, Greg
Post #485868 13th Aug 2018 4:56am
GraemeS
GraemeS wrote:
Another EGT sensor LR022893 (now LR052169) is located in the left manifold...
This being the sensor in question, I wonder if the original sensor's wiring couldn't withstand the exhaust heat allowing the wires to short together. At least the sensor has been revised so hopefully wont fail again if replaced.
Post #485870 13th Aug 2018 5:12am
GraemeS
Your logged temperatures correlate well with post primary turbo/pre cat, post cat/pre DPF, post DPF and post secondary turbo. I'm now confident that the manifold sensor is EGR inlet sensor / EGR sensor A.
Post #485872 13th Aug 2018 5:16am
GGDR
So maybe the manifold is the 5th sensor or other words, we can't see the readings for this?
. Cheers, Greg
Post #485873 13th Aug 2018 5:21am
GGDR
that seems to make sense as the EGR itself has only one sensor on the body of the EGR and I think EGR's need two sensors?
. Cheers, Greg
Post #485874 13th Aug 2018 5:27am
GraemeS
There are 6 in total, 2 being for EGR plus 4 in the exhaust pipes. We know that the EGR outlet sensor is in the cooler outlet pipe so the EGR inlet sensor, as shown in the wiring schematic, has to be the one in the manifold.
Post #485875 13th Aug 2018 5:28am
GraemeS
I couldn't work out which sensor in your log was the manifold as it should have been hotter than post turbo. Now I believe that the manifold sensor wasn't logged.
Post #485876 13th Aug 2018 5:30am
GraemeS
I'll see if I can spot the manifold sensor wire colours with just the cabin air intake removed. If 1 is brown and the other pink and white then they would correspond with the EGR inlet sensor colours.
Post #485877 13th Aug 2018 5:39am
GGDR
Starts to make sense more now. Given Nino's readings on I became really unclear. But now I think we're onto the problem.
Why the EGR temps aren't on the GAP I'm not sure. I'll have another look on the tool, but you said there was no EGR Temp value available. Weird.
But I'm ordering a manifold sensor! And yes the revision is probably a sign it's been improved. You'd hope.
In searching the web I found that the 4.4's bigger brother, the Ford 6.7litre Powerstroke deisels, which are made in the same Mexican factory as our 4.4's, suffer from EGT probe failures too. Replacements are $20 !!
. Cheers, Greg
Post #485878 13th Aug 2018 5:41am
GraemeS
$20? Not a LR price for sure!
Will you be buying the tool? I'll certainly be on the look-out for your comments on the task and hoping that Gap provide live values for the EGR sensors.
Post #485881 13th Aug 2018 5:57am
GraemeS
The sensor with the original part number appears to have a shorter metal section above the mounting nut than the current version where the wire connection point is further away from the manifold and shield.
Post #485883 13th Aug 2018 6:09am
