Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
,this is from my afternoon run, sensor that reads 100 on your car was at 360C just before i snapped the picture.
11th Aug 2018 9:14pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2532 |
My Euro4 engine shows 100 deg C for all 4 EGT sensors after a run and the P040D-00(2F) fault, if cleared, returns once the engine is started. I'll see if anyone else here can list theirs.
13th Aug 2018 12:15am |
I've just found a 5th EGT sensor - I initially missed the one behind the DPF.
13th Aug 2018 4:16am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Graeme, I was just typing to say I think there are 5 EGT sensors too!
Others say:
. Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
13th Aug 2018 4:56am |
This being the sensor in question, I wonder if the original sensor's wiring couldn't withstand the exhaust heat allowing the wires to short together. At least the sensor has been revised so hopefully wont fail again if replaced. |
13th Aug 2018 5:12am |
Your logged temperatures correlate well with post primary turbo/pre cat, post cat/pre DPF, post DPF and post secondary turbo. I'm now confident that the manifold sensor is EGR inlet sensor / EGR sensor A. |
13th Aug 2018 5:16am |
So maybe the manifold is the 5th sensor or other words, we can't see the readings for this?
13th Aug 2018 5:21am |
that seems to make sense as the EGR itself has only one sensor on the body of the EGR and I think EGR's need two sensors? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 13th Aug 2018 5:35am. Edited 1 time in total |
13th Aug 2018 5:27am |
There are 6 in total, 2 being for EGR plus 4 in the exhaust pipes. We know that the EGR outlet sensor is in the cooler outlet pipe so the EGR inlet sensor, as shown in the wiring schematic, has to be the one in the manifold. |
13th Aug 2018 5:28am |
I couldn't work out which sensor in your log was the manifold as it should have been hotter than post turbo. Now I believe that the manifold sensor wasn't logged. |
13th Aug 2018 5:30am |
I'll see if I can spot the manifold sensor wire colours with just the cabin air intake removed. If 1 is brown and the other pink and white then they would correspond with the EGR inlet sensor colours. |
13th Aug 2018 5:39am |
Starts to make sense more now. Given Nino's readings on I became really unclear. But now I think we're onto the problem.
13th Aug 2018 5:41am |
$20? Not a LR price for sure!
13th Aug 2018 5:57am |
The sensor with the original part number appears to have a shorter metal section above the mounting nut than the current version where the wire connection point is further away from the manifold and shield. |
13th Aug 2018 6:09am |
