Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor?
Page 5 of 15 <123 456 ... 131415>
GraemeS
Australia
I suspect that it might be worth the 50% extra cost to purchase the Laser Tool's 6-point version of the tool rather than the cheaper 12-point in case the sensor is somewhat seized in the manifold.
Post #485884 13th Aug 2018 6:24am
GGDR
Yes Graeme I've ordered the tool.
I'll take pics. A bit worried it'll be seized in there....
Hopefully be able to do it next weekend.
. Cheers, Greg
Post #485885 13th Aug 2018 6:24am
GGDR
Which one is the laser tool?
I can only find one 13mm sensor tool - which is the JLR one.
EDIT: ok got it there are 12 and 6 point versions. Was going to get the genuine one, can't find a pic of that....
. Cheers, Greg
Post #485886 13th Aug 2018 6:25am
GGDR
It's not crystal clear but the JLR looks 12 pointed in the WM:
 Cheers, Greg
Post #485887 13th Aug 2018 6:33am
GraemeS
Australia
Yes, too many points to be a 6-point.
Post #485888 13th Aug 2018 6:41am
GGDR
ok great shout I think I'll go for the 6-point
. Cheers, Greg
Post #485889 13th Aug 2018 6:51am
GraemeS
Australia
As the sensor has been revised, hopefully it won't ever need replacing again so you could sell the tool especially being a 6-point that is unlikely to get damaged. I suspect that I'll be replacing mine's sensor and the tool would be coming from the UK, possibly with a sensor in the same package to save on postage.
Post #485891 13th Aug 2018 7:39am
Baltic Blue
Greg,
Given that your soot level came down to 4.8 after a decent run out of town traffic shows that your car is functioning correctly despite the PO40etc alarm, exactly the same as mine and Nino’s, which have both been fine despite the fault being present for many thousands of miles.
Sometimes it is best to leave things alone.
“If it’s not broke don’t fix it” mentality 🤔🤔
Post #485894 13th Aug 2018 8:03am
GraemeS
Australia
I'd like to know if mine's single EGT sensor is used as a safeguard against excessive manifold temperatures if another sensor reads incorrectly yet is still within acceptable bounds. I intend eventually to get EGR mapped out so pre and post cooler temps purely for EGR control wont be required. In the meantime though, a non-operational sensor could possibly lead to more or less carbon build-up in the air intake. If the EGR inlet temp's default value of 100 deg is taken as gospel then the EGR cooler bypass valve will always be open, but IIDtool live value logging should reveal the valve's status.
Post #485911 13th Aug 2018 10:19am
GGDR
Hi Mike, well yes I know - the regen process is working well both Active and Passive, proven in the past week.
But my DPF does fill silly-quick. Almost in front of my eyes. I sat in traffic and watched it go up. Yes I'm doing 20mph most of the time, but since I had it removed and cleaned then reading zero, it filled up to 23g within in think just over a week of short journeys.
I don't believe that's normal. Plus I have a diesel smell on cold idle. That's one of the symptoms Craig mentions.
Craig said;
Quote:
The first code is for a sensor in the NS exhaust manifold, this tells the ECU its running lean or rich this then increases or decreases the fuel trim... If it fails in one position then it will over fuel the car and it makes the exhaust STINK like a 1970s ice cream van! This will fill the DPF prematurely and cause restricted performance issues too...
...and similar on quite a few posts:
A bit more trawling through the forum shows a different error relating to EGR temp sensor B and I now think B is on the EGR itself.
The lack of identification in the workshop manual means ambiguity (at least outside of LR dealerships is) about which sensor is which - sensor A which I believe is on the manifold, nowhere near the EGR vs sensor B, may well have led many to replace the wrong sensor, and then have the error return.
Without knowing the manifold sensor is even part of the EGR calculations and being nowhere near the EGR, you get an error saying EGR sensor A fault. So you change the EGR sensor on the EGR. And the fault returns.
I think may have done this, or their mechanics and this has fuelled the 'they all do that' thinking.
I also agree with Graeme that an incorrectly controlled EGR = soot, wrong fuel/air mix etc.
The part number for that sensor has been updated suggesting an improvement has been made to the sensor.
If I wasn't having any other symptoms I'd definitely leave it. But my fast-filling DPF is a right PITA. On the other hand, if your DPF isn't giving you trouble, you may be fine to just leave it.
. Cheers, Greg
Post #485987 13th Aug 2018 6:04pm
GraemeS
Australia
Patrick @ Gap advised that their tool has the complete live value list implemented by LR.
I note that the wiring schematic incorrectly labels the 2 EGR temperature sensors as a 2nd set of pre and post catalytic converter EGT sensors, with the descriptions corrected in a correction document. With live values available for other EGR components and operation, it appears that the EGR temperature sensors were missed in more than one respect.
Post #486015 13th Aug 2018 9:37pm
GGDR
Found this in the workshop manual:
What I think many don't realise, as mentioned ^^^ is that The inlet sensor, called Sensor A is (probably*) on the manifold and not on the EGR.
Sensor B (likely the one on the EGR) has it's own, different error codes such as P041C-00 and P041D-00
*this is not documented (part of the problem) as far as I can see in the WM but there are several contributing factors to this including CTC's advice.
. Cheers, Greg
Post #486113 14th Aug 2018 7:58pm
GGDR
BTW I'd be interested in knowing what 2F means.
Anyone know?
. Cheers, Greg
Post #486115 14th Aug 2018 8:11pm
GraemeS
Australia
The wiring for the EGR inlet temperature sensor is on the engine as is the wiring for the EGR outlet temperature sensor, so another indication that the sensor is the one in the manifold.
Post #486118 14th Aug 2018 9:21pm
GraemeS
Australia
Mine's EGR cooler bypass valve opens and closes depending on throttle usage once the engine warms so presumably is not affected by the failed EGR temp sensor.
Post #486140 15th Aug 2018 9:09am
