![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
100 degrees is the minimum value I believe Graeme
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
Just checked mine, same fault code and same 100 degree reading as yours. |
Should probably add I thought I’d added a photo of the readings but my IT skills have failed me
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
temperature on the bank 2 sensor 1 will go above 100 C only if the engine is spinning over 23~25 hundred rpm. in the pic. you can see temp. have gone up so the sensor is working. i have had it. go up ove 280C while the revs are kept up above 23 hundred rpm,s.
Ok cheers cass - was your engine hot?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
In that case that sensor must be the one in the exhaust pipe from the secondary turbo on the left side of the engine.
Euro 4 only has temp sensor in left manifold and oxygen sensor after primary turbo - only measuring EGT in 1 manifold (no need to measure both). Bank1 sensor1?
So Graeme this shows my 4 EGT readings.
Nino do you have the error?
I'm also wondering if Pat @ Gap might know which one is which one...
Yes it was hot, they all read 100 when it was cold.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
Your I T skills are twice as good than earlier |
I have, it was there first time i checked with IIDTool +/_ 100K km now.
Nino I think you have disproved part of my theory probably then that sensor reads temp post turbo number two. Which makes sense baciase all readings i've taken are under 2k revs. Cheers, Greg
