Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor?
Page 15 of 15 <123 ... 131415
minim
Norway 2013 Range Rover TDV6 Santorini Black
But if you look at the live values the Bank 1 sensor 3 has values so the live values doesn't add up with the error code. And sorry, replying from a computer now I see that I posted in a 4.4 TDV8 thread and mine is a 3.0TDV6 if that matters.
Post #689950 4th Apr 2024 9:32pm
kokamagi
Estonia 2011 Range Rover Autobiography TDV8 Santorini Black
Yes the readings seem to be very healthy. Might be intermittent problem. Maybe check the wiring and connectors first, wiggle them around. I believe B1S3 is reffering to the same sensor on both engines.
Here's the explanation from 4.4 TDV8 WSmanual.
Post #689966 5th Apr 2024 5:51am
minim
thanks. I'll have a look there. I checked the TDV6 manual now and it's a bit more confusing as it says Bank 1 sensor 3, on the error code side it says bank 2 sensor 2 and it describes it as the sensor post catalytic converter.
Then there's a bit confusing values when reading the sensors. I did a pull uphill and took this screenshot. Bank1 sensor 1 is according to the manual "temperature in the turbine housing". Shouldn't this be the highest temp as it's closest to combustion? Then Bank1 sensor 3 is highest and that's according to the doc above past the catalytic converter and should be lower than Bank 2 sensor 1 that is pre cat. Bank 2 sensor 1 has the same weird fault as in the above screenshot that it's named Bank1 sensor 2 in the code and on the right side it says Bank 2 sensor 1.
With all this mess it's tempting to pull the sensor connector if I can reach it to spot what sensor is what in both live values and fault codes.
Post #690036 6th Apr 2024 12:41am
kokamagi
On your screenshot you had DTC P242A-00, but from the manual you are looking at another DTC P242A-22.
The highest value should always be after the cat not before, when everything is working as it should, because of the catalytic reaction taking place in the cat. The logical order of the sensors labeling should be: b1s1 - before cat, b1s2 - after cat and before dpf, b1s3 - after the dpf. Since your b1s2 is always showing 0, the problem might be in the sensor after the cat OR data might be mixed up in the IIDTool software.
Usually regarding the EGT sensors the lowest showing value should be 100 not 0, because they are calibrated to start reading from 100C.
B2s1 would only rise above 100C, when accelerating over 2500rpm and secondary turbo is activated.
Post #690045 6th Apr 2024 8:04am
minim
The 00 doesn't show in the 3.0 tdv6 manual so I used that screenshot since it's talking about the same sensor (b1s3) and is mixing it with the other. All the 242 is mentioning b1s3 and have the same mixup in the description to the right.
In the manual it says "if equipped" on all the sensors so I assumed that the one showing zero isn't used on my engine. Forgot to mention that this screenshot is taken without any error code present and that my error only shows up from time to time. I've only seen it twice since I purchased the vehicle 4000km ago and I noticed it in the logs when I scanned it before I bought it but then it didnt reappear for weeks.
Post #690048 6th Apr 2024 8:13am
kokamagi
I added some pictures from my normally working 4.4tdv8 system to my last post and explanation why b2s1 is reading 100.
Here I added to your first screenshot what I assume would be correct labeling of the EGT sensors.
You might want to consult with GAP Diagnostics team, they are very helpful.
Post #690051 6th Apr 2024 8:30am
GregPrice80
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
Has anyone experienced this fault code along with an occasional yellow restricted performance on starting the car? And did changing the sensor get rid of the warning? 2010 Range Rover 4.4TDV8 Autobiography Black Edition
Gone -
2005 Discovery 3 2.7 TDV6 S
2002 Range Rover 3.0 TD6 HSE
Post #690077 6th Apr 2024 11:25am
minim
Thank you for the info. It's just like you say on the throttle with that sensor after the turbo. So then I got 4 working sensor and I can only assume that the one earlier at zero was just not used on my car. The fault is gone for now so I'll inspect wires and unplug senors to test next time as it seems unclear what sensor is what still. I'll check with gap also.
As for the yellow reduced performance that comes with my 242 error code when it's there. If I clear the code it's fine again for hundreds of km and many starts.
Post #690092 6th Apr 2024 1:49pm
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
I've just purchased my GAP tool (IIDControl 4.2.11 Build 168 Android - IIDTool BT V4.0 B3998) and this is the only fault that is recurring on my vehicle. On the first code read there were a lot of codes from July when my MD fitted a new battery and alternator.
I notice that while it was at the MD in July the following fault occurred:
P040D-00 - Exhaust gas recirculation temperature sensor A - circuit high (2B)
I've since cleared all of those to see what still occurs now.
This morning for example I saw this before my journey:
I cleared the codes and after my journey I saw this:
P040D-00 - Exhaust gas recirculation temperature sensor A - circuit high (2F)
But the timestamp of that fault is from before my journey.
What is the difference between 2B and 2F? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #701883 9th Oct 2024 11:48pm
