Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor?
Page 13 of 15 <123 ... 12 131415>
DrRob
I’d just leave well alone. Lots of us have that code to no ill effect Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530644 12th Oct 2019 8:18am
DrRob, the fault code relates to one temp sensor in the N.S. manifold. Depending on how this sensor fails? Im guessing from one end of the temperature scale to the other? Some clearly don't give problems "like yours" whereas mine when it failed, it made the exhaust stink, due to overfueling the car! This filled the DPF with unburnt fuel and gave me no end of DPF regeneration issues! Censored
Post #530706 12th Oct 2019 11:16pm
DrRob
I had mine replaced recently at Rovertune at minimal cost as part of a wider list of jobs being carried out. They replace a lot apparently on a regular basis so have the experience and tools to do it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530708 13th Oct 2019 8:15am
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
PDF FULL
First its a thanks to everyone's contribution on this topic and I am pleased that I found it. I've had mine RR for three years without the dreaded message but it appeared a few weeks ago. What was pleasing in a way is that I'm not the only one and that members have the knowledge and are prepared to enlighten others! During my first service at an Ind. garage. I had a EGR sensor fitted - Dec 2017. The following year the service was done but they reported the P040D-00 error code and two sensors were fitted as they didn't get a regeneration after they fitted the first to the EGR. I looked back at their invoices to see these comments this week and the 10 hrs plus sensor costs. In fairness I was told "we have NOT done this before" and I didn't get a quote from them either. What may be of interest to everyone was that they removed the nearside front wheel arch cover and removed fuel filter and other bits (I'm no engineer) to do it. Just wondered if that seemed to be helpful to anyone?
Needless to say I decided to do what servicing I could do myself after the help gained from the forum membership. This way ensuring jobs were done and the right items such as oil etc were used. I have a good local garage for anything basic underneath!
I will watch out for the "FULL" message again but realise now that my driving style now retired, country lanes here and lock down don't help. Also to drive it as it is meant to be!
So thanks to all
Dave
Post #568056 26th Sep 2020 12:05pm
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Dave, many thanks. Like you, retired, not many long runs. Wow 10hrs, my Indy charges £50 per Plus how to decide which sensor to fit. More thinking to be done. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #633471 1st Jun 2022 3:34pm
Baltic Blue
Like many others I have had this fault code showing for years.
I bought the replacement sensor 5 years ago but was strongly advised by the indi I was using at the time to leave well alone unless it really started causing any problems.
He explained carefully what work was involved , then told me the last one that they did cracked the manifold as they struggled to remove the old one.
I passed all the info onto Greg when he started this thread and decided to leave mine whilst the car was running well.
The new sensor is still in the box ,just in case Rolling with laughter
Post #633472 1st Jun 2022 3:52pm
GrandadRob
So can anyone put an estimate for a garage to fit one. Nylands said 10 hours plus. That’s prohibitive. Can I do it myself .? 2013 SDV8 4.4 SE Luxor.
Post #633476 1st Jun 2022 5:26pm
johnboyairey
I’ve just been down this route… there is a wiki section on replacing it.. it’s a rotten job, and mine broke off. So no chance of actually replacing it, without removing the actual manifold. I have a new sensor, and when plugged in, and left dangling by the manifold, it obviously clears the code alarm… however it doesn’t get hot there, and doesn’t do it’s job. So I decided to experiment, and heat up the sensor, and measure the resistance at hot temps. Took it all the way to red hot, and got a max resistance of 650 ohms. So I ordered a 650ohm resister, which I plan to fit on the wires that feed the knackered sensor. Ie cut the wires off, fit a resistor, and drive it. That sensor will then reads hot exhaust, and should allow a regeneration, when other factors allow.. ie other sensors, speed etc. when I get the thing fitted I will report back. For what it’s worth, I’m not planning on removing the manifold as it looks a hell of a bad job, and will no doubt give me another problem…
Post #633492 1st Jun 2022 9:51pm
Phoenix
It may well be possible to get a spark eroder in there, that'd get enough of it out for you to clean the threads up. You'd need to drop the exhaust off the manifold so you're not pushing the waste into the CAT / DPF though.
Post #633493 1st Jun 2022 10:11pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I had my last FF done by LR some 3 years ago and the list hours was quoted as one hour?
and took them two hours, but still only charged for one.
My Indie quoted 2.5 hours.
I did the sensor on my present FF and it took me a couple of days, I think the trick is to soak it and get it hot, soak it, heat it, and so on and it will come undone but only if you undo it without strain to the side? a 1/2" deep socket will help to get it out it is a Censored but doable
Post #633495 1st Jun 2022 10:28pm
Phoenix
If it was a job I was doing, I'd cut off all the gubbins above the nut, heat with a small oxy-propane torch to keep the heat localised, get it cherry red, allow to cool and heat to cherry red again, then get a single hex impact socket (less chance of wear on the shoulders) on it with a 'T' bar using lots of side-to-side movement to free the threads, if it's not in the mood to move, then Plasma or spark eroder before anything is sheared off - less chance of damage to the manifold threads.
Post #633497 1st Jun 2022 10:56pm
Davidmudley
I just spoke to a Surrey LR main dealer who has quoted £840 (unclear of this is inc or ex VAT) but they also mentioned the worst case scenario would be if they had to take the engine out to replace the sensor.
Seems like they’re coped onto how nasty this job is.
I’m more tempted to give it a go myself now after that. Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #638572 3rd Aug 2022 9:48am
Baltic Blue
Getting lots of penetrating oil onto it is definitely key, also a good fit six sided deep socket, not the special tool to loosen it, that’s just for fitting the new one.
Post #638583 3rd Aug 2022 1:48pm
DrRob
Have you called a few independent specialists? Don’t forget we now have a forum sponsor close to you just nr Liphook on the A3. www.glenrands.co.uk
All LR trained technicians etc Thumbs Up
Loan cars too Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638596 3rd Aug 2022 4:39pm
johnboyairey
you can save yourself a whole lot of grief, and get a guaranteed code clear, if you use my resistor fix, as detailed above. -been working fine for a few months now. the old nut, should it break, and become loose, it will allow an exhaust 'blow' which will have to be addressed.
total cost, about 20p!
Post #638621 3rd Aug 2022 10:10pm
