![]() | Home > Technical (L322) > Delayed Air Con |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Thanks guys.
Just done a search for that part number.
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
Does the kit from Island 4x4 include replacement seals for the refrigerant pipes where they attach to the compressor? Or are they not required?
I don't think so, looking at the picture it is just the valve and circlip.
Can anyone confirm that for the L322 LM 2010 - 2012 the correct compressor oil is PAG46?
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2563 ![]() ![]() ![]() |
The TSB states the cause as the valve being worn although I understood that it was a valve design issue, now rectified, but possibly prematurely worn due to a design shortcoming. |
Yeah, given the number of hits for this same issue on VAG cars using and having issues with PCVs, I would agree with Graeme that it is likely an issue with the valves.
OK, work is under way.
In this pic, you can see the electronics that sit over the airbox sat on the strut.
Thanks Graeme |
Job completed.
Good job and a good write-up too! |
Thanks Graeme.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
John, can you post link to Dropbox so that we can download the pictures directly?
