Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 99 |
Anybody tried this yet or is it still too cold ? |
31st Jan 2018 11:25pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 334 |
Still to cold and wet for me! |
31st Jan 2018 11:35pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Ok I got off - lots of sweating, trapped fingers and a broken lug but it is possible to remove the rigid back with the seat in the car. Just. Now I'm looking for a fault with the heating unit...
24th Feb 2018 3:49pm |
Meant to say swearing not sweating. Not in this weather anyway!
24th Feb 2018 3:51pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
its interesting to see whats actually in the back there... ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
I suppose at this age and mileage that we have all done now, we will have to put all these seat problems down to wear and tear rather than faults, but good to know where to look when problems arise.
24th Feb 2018 5:20pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
I haven't read all the thread - but my drivers seat heating failed on my last L322, it was the seat blower motor that went - MD replaced it under extended warranty 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
24th Feb 2018 7:07pm |
Removed the motor/heater unit. The split in the ducting went right around to the other side.
25th Feb 2018 1:58pm |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 136 |
I had the same after a repair..... Worth taking the filter off the lower fan and see if it’s still running.....mine does and the seats get warm after a few mins even tho it sounds like they’ve stopped |
25th Feb 2018 7:54pm |
Cheers Andy. When you turn the dial on there's a strong fan sound for 5 secs Then that sound drops down and I can feel the (lower) fan running with my finger. Then fan stops altogether after around 20 secs.
25th Feb 2018 8:10pm |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55 |
i had the same problem, but there was no visible damage so presumed it was down to the peltier cell so in the end i just purchased a new unit from LRdirect, fitted it in and it all works fine now, good luck FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
26th Feb 2018 7:52am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Greg, when I turn heat on mine seat there is no fen sound, none, and mine are working very good.?
26th Feb 2018 12:37pm |
From memory, when cooling the fan under the seat base will spin and can be heard rotating but on heating it stops FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
26th Feb 2018 1:16pm |
ok thx guys. I'd better let it run for 20 mins. At £215 quid for the part, I def want to be sure before I pull that trigger!
26th Feb 2018 1:20pm |
