![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
That is absolutely correct, and from what I can see the go directly into the plates. As soon as my replacement arrives, I’m going to break it open. 😁 |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55 ![]() ![]() ![]() |
in regard to the heated/cooled seat control module, i see lots that look identical but have different part numbers, mine is
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 ![]() ![]() ![]() |
Millerj90i was hoping to hot wire mine into working with an external thermistor, and use the whole assembly to heat the air in my biltong drying box! But I was a little over enthusiastic with the tear down |
Zeppfish - great idea, good biltong is hard to get around here! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3887 ![]() ![]() ![]() |
This got me to thinking - again dangerous - a thermistor is just a heat sensitive resistor so if the value of the resistance was known for a given heat the thermistor could simply be replaced with a resistor in line for a fixed heat setting. Geoff |
Geoff
I think its time I got my order in, if only to stop comments regarding my more than ample arse that needs warming up on a regular basis |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
Has anyone tried swapping the peltior unit from the squab into the seat back to see if it resolves the non heating problem without spending £260 on a new back module (heater and fan unit )?. |
Unfortunately the pettier cell in the back has the thermistors in, and the squab has none as the back unit controls the pair! 2006 RR sport HSE
Are you sure as looking at my underseat one it has the same 4 wires (2 green , 1 blue and 1 yellow) going into it as the one in the seat back ? Surely as it's a separate unit it will need the same type of temp control to stop any overheating . |
I was only going from memory as mine happened early last year!
Has anyone done this yet, did it work? Geoff |
Not yet. Weather has not been conducive to ripping the seat out. But it does make a whole lot of sense |
