![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 ![]() ![]() ![]() |
That's good to know. Where did you obtain the WM? |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
That looks just like mine Stan.......my first effort was to replace the turbo feed O rings, but on checking the coolant, it was clear that i'd need to dig a bit deeper and replace the cooler gaskets. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35545 ![]() ![]() |
i haven't any oil in my coolant thankfully so mine is either the o rings (job to be done) or the oil cooler which if it is that will be done by the dealer.. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
Stan,
i have a set of ten [ebay] Mike and i doubt if Dan sells them and if he did they wouldnt be the viton ones and would probably cost the earth .. ... - .- -.
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
does any one have a link to the correct o rings for the rear pipe and the part numbers for the oil cooler gaskets, my 11 plate 4.4 is leaking both at the rear and down in the v.
the o rings are bs611 viton
Page 8 of this thread has Nino''s pictures of the gaskets and their part numbers used to repair the oil cooler. |
stan, thanks O rings for the back ordered.
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 ![]() ![]() ![]() |
The bottom gasket that the oil filter assembly sits on is LR022903. Not sure where you get the other number from? However if you’ve got the whole assembly apart I’d change both gaskets at the same time given the labour time to dismantle. Chris |
Many Thanks, I will get the parts ordered and get into this early next week.
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
Started to see the odd spot of black engine oil on the driveway, and thanks to this excellent thread, I was able to find the problem and do a DIY fix. So if your TDV8 4.4 starts to mark its territory, read through this thread in its entirety, and don't be deterred from doing it yourself.
Scuddriver,
Thanks Mike. I'll see if Dan can supply 2011 Vogue TDV8 4.4
