Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 |
That's good to know. Where did you obtain the WM? |
11th Feb 2018 6:22pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
That looks just like mine Stan.......my first effort was to replace the turbo feed O rings, but on checking the coolant, it was clear that i'd need to dig a bit deeper and replace the cooler gaskets. |
12th Feb 2018 8:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
i haven't any oil in my coolant thankfully so mine is either the o rings (job to be done) or the oil cooler which if it is that will be done by the dealer.. ... - .- -.
12th Feb 2018 9:03am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Stan,
12th Feb 2018 9:54am |
i have a set of ten [ebay] Mike and i doubt if Dan sells them and if he did they wouldnt be the viton ones and would probably cost the earth .. ... - .- -.
12th Feb 2018 9:57am |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 157 |
does any one have a link to the correct o rings for the rear pipe and the part numbers for the oil cooler gaskets, my 11 plate 4.4 is leaking both at the rear and down in the v.
12th Feb 2018 8:50pm |
the o rings are bs611 viton
12th Feb 2018 8:55pm |
Page 8 of this thread has Nino''s pictures of the gaskets and their part numbers used to repair the oil cooler. |
13th Feb 2018 8:41am |
stan, thanks O rings for the back ordered.
13th Feb 2018 6:44pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
The bottom gasket that the oil filter assembly sits on is LR022903. Not sure where you get the other number from? However if you’ve got the whole assembly apart I’d change both gaskets at the same time given the labour time to dismantle. Chris |
13th Feb 2018 8:22pm |
Many Thanks, I will get the parts ordered and get into this early next week.
13th Feb 2018 9:20pm |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 |
Started to see the odd spot of black engine oil on the driveway, and thanks to this excellent thread, I was able to find the problem and do a DIY fix. So if your TDV8 4.4 starts to mark its territory, read through this thread in its entirety, and don't be deterred from doing it yourself.
17th Feb 2018 2:42pm |
Scuddriver,
17th Feb 2018 5:47pm |
Thanks Mike. I'll see if Dan can supply 2011 Vogue TDV8 4.4
17th Feb 2018 7:32pm |
