Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 10 of 38 <123 ... 91011 ... 363738>
carpcat
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I have my 2 oil cooler gaskets arrived from Dan at Duckworths so looking to do the job this Saturday if I get the time. Got some Hylomar Blue as mentioned previously, and brake cleaner for the cleaning of the manifold sensors. Anything else that’s worth doing at the same time? Chris
Post #463325 4th Jan 2018 8:32pm
mpirie
Just the interior of the inlet manifold......a small job, but very dirty.
Not sure if it makes much difference once done, but it did satisfy my OCD for a while Laughing
Mike
Post #463391 5th Jan 2018 10:01am
Baltic Blue
160 dmb,
Thanks πŸ‘πŸ‘
Very kind.
Cheers
Post #464287 12th Jan 2018 1:47pm
it appears that i have been honoured with this problem..
anyone had it done under warranty? ... - .- -.
Post #467341 4th Feb 2018 9:34pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Mine was done under LR warranty. What do I put here then?
Post #467346 4th Feb 2018 9:49pm
interesting....how did you present the problem/details to the dealer ? ... - .- -.
Post #467350 4th Feb 2018 9:54pm
Sandyt
In the old days Stan this was a corrosion preventer that all Range Rovers had so no corrosion underneath
Thumbs Up Thumbs Up Rolling with laughter
Post #467359 4th Feb 2018 10:15pm
GGDR
Bummer. How many miles are you at Stan?
Do you think oil cooler or the o-ring thing?
Greg Cheers, Greg
Post #467361 4th Feb 2018 10:19pm
GAC23
I just explained the symptoms- car stank of hot oil after use ...
... the longer the run, the greater the smell. What do I put here then?
Post #467370 4th Feb 2018 11:36pm
Baltic Blue
Has any oil got into the coolant ? or the V at the top of the engine?, or is more likely just the β€œ0” rings ?
Stan,
Has it just been in for a service?
Is it possible that they spilled some oil out whilst changing the oil filter?
Post #467385 5th Feb 2018 8:25am
morning chaps...
no oil in the coolant Mike so i suppose that points to the 'O' rings ..
@GAC23, i was hoping for something more technical so i could direct the LR numpties to the precise problem so they dont come back with 'nothing found'...
@Greg, miles are 81000 and no oil in coolant..
@Sandy, Ner Ner Laughing
i dont think my back in its present state will let me do the job myself so i'm tempted to ask Craig to do it... ok it will cost but at least i know it will be done properly..
i'll let you all know what happens.. Thumbs Up ... - .- -.
Post #467395 5th Feb 2018 9:48am
GAC23
Sorry, Stan ... that's all I told them - was all I knew.
Luckily they found the problem and fixed it. What do I put here then?
Post #467400 5th Feb 2018 10:20am
thanks G, i have LR assist coming tomorrow morning so hopefully the tech will know the proper 'wording' of the problem... ... - .- -.
Post #467402 5th Feb 2018 10:30am
GAC23
You certainly want to hope they're more technical then me, Stan Laughing What do I put here then?
Post #467404 5th Feb 2018 10:36am
well LR assist have come and gone and the chap confirms that there is an oil leak at the near side rear of the engine block..he didnt get any mirrors or endoscope out so i'm sure what is leaking but he thinks its most likely the oil seals..
time to get it booked in with a dealer.. ... - .- -.
Post #467533 6th Feb 2018 11:54am
