Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 9 of 38 <123 ... 8910 ... 363738>
Baltic Blue
Just wondering Nino/ Mike,
Did you put the new rubber gaskets in dry (ie straight out of packet), or did you oil them?
Mike. B.B. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #462607 29th Dec 2017 12:56pm
nino_nino
I forgot to mention, bit of fresh oil-same as oil filter O ring. Thumbs Up
Post #462616 29th Dec 2017 1:27pm
mpirie
I used a very thin smear of Hylomar Blue (non setting gasket).
Mike
Post #462664 29th Dec 2017 8:59pm
160dmb
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
I just tried the link to get โ€˜Oโ€™ rings but it doesnโ€™t work anymore - i can try and find an alternative supplier on ebay but wondered if anyone who had spares from an earlier repair wanted to sell me a few of the BS611 viton O ring they might have lying around.
Hoping to get this done of Friday so time is a bit of the essence.....
No stress if not. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
2014 (L405) VSE in Black with Ivory
2011 (L322) VSE in Black with Ivory
2005 (3.2 V6) Porsche Cayenne in Black with Savanna
1999 (P38) VSE in Burgundy (?) with Sand
Post #463044 2nd Jan 2018 6:04pm
nino_nino
I am too far to send you, here is the link for british company-
https://www.ebay.com/itm/BS611-1-78mm-Sect...ZKBH95UhnQ
Post #463047 2nd Jan 2018 6:28pm
don't they have to be BS611 nino? ... - .- -.
Post #463048 2nd Jan 2018 6:31pm
nino_nino
I edited ,
Post #463051 2nd Jan 2018 6:34pm
Baltic Blue
If you PM me your address, I will send you 2 by first class post tomorrow morning, so they should be with you for Friday.
Post #463056 2nd Jan 2018 6:43pm
160dmb
You have a PM and my gratitude Mike. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #463091 2nd Jan 2018 10:30pm
Baltic Blue
Posted.
Good luck with repair.
Tip: Tape over outer groove whilst fitting first O ring.
Cheers
Post #463113 3rd Jan 2018 9:18am
160dmb
Thanks for the tip - and the O rings - I had taken note of the tip from your earlier post!!!
Great help.
Thanks again 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #463125 3rd Jan 2018 11:11am
160dmb
Arrived this morning Mike - thank you send me your address by PM and I will at least send you some stamps.
Fitting this afternoon 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #463247 4th Jan 2018 10:37am
160dmb
Done.
For anyone else's reference it took 20 mins start to finish with absolutely no rushing.
Really quite easy because of the instructions on here. 2016 (L405) Autobiography in Black with Ivory - for ULEZ
Post #463309 4th Jan 2018 6:44pm
Baltic Blue
Brilliant ๐Ÿ‘๐Ÿ‘,
Cheers
Post #463312 4th Jan 2018 7:06pm
Well my little bag of prints has arrived, for when it starts leaking. For a few quids it was worth putting them in the tool box for future use!! There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #463313 4th Jan 2018 7:11pm
